New High Torque Starter Connection prob . - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2007, 08:13 PM
Ok Guys ,, Here is my thing on this New Starter ..
I have a 70" BBC .. I swaped the old starter of the engine , & I got me a Mini starter ..
I got it all hooked up & tried to start the car .. BUt The starter would just spin ..
The Shaft would not come out of its shell for some reason ..
It just spins ... ( I was thinking I might have switched the wires wrong )
I gave up ,, & I took the starter to get checked ,,, & It checked good ..
They hooked it up to the tester ,, & shaft came out properly ,,, The way it was supposed to ..
So I took it home & tried switching the wires around again , But It still did the same thing (Nothing but just spin ) Without the shaft coming out ...
Can someone please Help .... ?
The wiring harness & car is a 72 Camaro ... Stock starter had 3 wires connected to it , PLus the Battery cable ...
Old 12-29-2007, 10:34 PM
71corvette's Avatar
is the battery strong enough? if so check the ground. sounds like it is not getting enough voltage to spin fast enough to engage the bendix
Old 12-30-2007, 06:24 AM
31 five window
Last journal entry: grill and rear end
71corvette You Got It.
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
84' 350 SBC Starter Problems Gokussj5okazu Engine 8 05-14-2007 05:16 PM
torque converter banging??? Flywheel or tranny?? boneyard Buick Engine 5 09-04-2006 03:07 AM
ford v6 torque Bob Ruth Engine 9 06-26-2003 12:05 AM
What Can I Really Expect From a High Stall Torque Converter ? white66coupe Transmission - Rearend 3 05-25-2003 05:21 AM
