new holley 650 backfires - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 11:09 AM
Last journal entry: door trim
I have a new holley 650 db pump/manual choke on new hi-rise manifold. built sbc in streetrod, engine starts ok but bogs down a little when i first hit the accelerator then when i shut the engine off it pops through the mufflers.
Old 08-05-2010, 01:17 PM
bubbahotep's Avatar
Check your timing.
Is the carb adjusted or just dropped in? Idle mixture, float levels, idle speed?
Old 08-12-2010, 07:29 AM
carb issue
this is a 350 sbc bored to 360 fuelie iron heads, 202,160 ported, block was blue printed, 450 lift cam, it's either 10.5 or 11 to 1/ compression I can't remember. I set the floats, used vacumm gauge to set idle mixture. I was told not to use the vacumm advance on the distributor so it is blocked off, due to the high compression.? New HEI GM distributor , this motor has less than 10 hrs on it. not sure if this is the way to go. thanks
Old 08-18-2010, 06:16 PM
carb
I think the it was a competition cam with a 455 lift, I can't remember excatly . it was 10 years ago that I had the engine built.
Old 08-19-2010, 02:39 PM
dist adjustments
how hard is it to modify the distributor? It's a new HEI gm. Ir is there a better aftermarket dist that i could that doesn't need any modifications? If there is would it be alright to then use the vacumm advance and what would i set the timing at. thanks pc
Old 08-20-2010, 02:21 PM
If I don't have to take the motor apart I don't mind doing the work.
Holley 600 650 ? ImRoyaltyInMyChevy Engine 10 11-04-2008 03:13 PM
Holley Carb FUN (for Barry Grant Guy also) PutPut72 Hotrodders' Lounge 21 10-24-2008 09:35 AM
Need to downsize from my 750vac sec Holley. Want your choice of carb and why! club327 Engine 20 02-05-2006 10:27 PM
Holley throttle body Kevin45 Engine 1 06-10-2005 11:46 AM
Bigs 650 Carb 1965-Mustang Engine 6 11-25-2003 07:47 AM
