Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New to the hot rod world
Old 11-01-2012, 09:42 PM
Jerry72c10 Jerry72c10 is offline
Thank you I highly appreciate that...... Little by little I'm seeing I have a hell of a lot of work starting with replacing the cab. as I removed the air conditioning boxes, heater chore, wiring harness, and controls I just find more and more problems with rust and wiring..... The wiring is no's the rust I'm worried about...... Also I'm having a problem with the column shifter that it's extremely loose and doesn't lock into any great which caused me to put it between gears and mess something up so now I have to shift from low to high manually.......and it will only shift in high's just a pain to find another th350 here in orlando....
