Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New to Hot Rodders site building 1966 Chevelle 310
Old 08-12-2012, 05:24 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
I wouldnt go much past 10.5:1 either,single plane might give more top end,600 lift cam is probably correct depending on the air flow of your heads? I would use an 850 holley double pumper and 1 3/4"
primary tubes headers. the engine will need to rev past 6000 so you will need transmission and gearing appropriate to your useage.
