New to Hot Rodders site building 1966 Chevelle 310 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2012, 03:05 PM
I've read some post about the 383 stroker engine on this website and was hoping for some guidance.
I have a 350 block that was decked to zero that is .030 over. I'm going to have to go at least to .040 because the pistons currently slap.
So I have this block that is ready to go and another block that wasn't decked standing by.
I have the RHS racing heads 200 runner Pro action. I also have the RPM Performern Air Gap intake manifold, high flow oil pump and water pump. I will use an electric fuel pump.
I hope to use either the 383 kit from White Performance kit number 4340 with either flat top or domed pistons or a kit from Skip White part number P3832P-.040.
I talked with Lunati and they recommend a .600/.600 lift roller cam.
Its a lot of info but I am also trying to achieve over 500hp/tq and still don't have a recommended carb.
With the exception of the heads, no part has been bought so please substitute if it will help attain my goal.
Thank you.
Old 08-12-2012, 04:46 PM
bigdog7373's Avatar
Of course it's fast
What are you thinking about for compression? You'll have to go decently high but i wouldn't take it past 10.5:1 if you want to stay on pump gas. I don't think you will hit 500hp. Not without using either race fuel of forced induction. I could be wrong, but 500 seems a bit wishful.
Old 08-12-2012, 05:24 PM
vinniekq2's Avatar
I wouldnt go much past 10.5:1 either,single plane might give more top end,600 lift cam is probably correct depending on the air flow of your heads? I would use an 850 holley double pumper and 1 3/4"
primary tubes headers. the engine will need to rev past 6000 so you will need transmission and gearing appropriate to your useage.
Old 08-12-2012, 05:50 PM
bigdog7373's Avatar
Of course it's fast
Op, if you really want 500hp i would go with a blown 355. You'll hit the 500 mark easily and driveability will be better since you wouldn't need a massive cam.
Old 08-13-2012, 08:49 AM
Thank you for the responses.
I don't want a blown motor because I want it to be a sleeper. I am looking into an AED 850, cam is .560/.565 and 243/251 at .050 duration. Compression is between 10.7 and 11.02. Will probably use Skip White's 383 stroker rotating kit but I can't get them to rerturn my calls so I started looking someplace else.
I have the TH400 and the 410 rear, intake manifold is currently a RPM Performer Air Gap but can be changed if necessary.
Thanks again,
Barry
Hot rodders a family site? painted jester Hotrodders' Lounge 45 07-24-2012 09:03 PM
1966 chevelle denniso Introduce Yourself 1 02-14-2009 08:18 PM
hello to all the hot rodders in this site srhspade@msn.com Introduce Yourself 2 01-31-2006 05:12 PM
1966 Chevelle juiced66malibu General Rodding Tech 2 09-22-2005 10:24 PM
1966 SS Chevelle Si3 Electrical 3 10-20-2004 02:21 PM
