Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New hydraulic lifters
  #27 (permalink)
Old 01-28-2013, 10:35 PM
71nova355's Avatar
71nova355 71nova355 is offline
Im a nobody, but just thought I would add that I just watched a few you tube videos (shop or company how to videos) and this seems to be a very debated subject. Most lifters come with directions tho and that seems to be the best procedure to follow. That being said, hydroulic lifters as I haved learned, should be lubed but installed dry and unlocked up. Preload set between a 1/2 and 3/4 turns past zero lash and using the twist method to find when tension just starts(zero lash) just my 2 cents setting hot is only done on solid lifters after having been set cold intially.
