a new idea? maybe - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2005, 05:41 AM
crzy4507's Avatar
95Ranger
a new idea? maybe
Damn... i feel like an idiot, askin so many questions from everyone here, but everyones been aot of help and i want to thank them real quick... and ask if anyone knows anything about putting bondo or somehting like that between the can and the bed/camper on a truck, like to give it a cleaner look... i have a feeling this may be dumb because of the truck needing to twist and bend or anything like that but i was just wondering if anyone knows anything about this... thanks again for any help
Old 07-13-2005, 08:43 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
Your cab and bed move independently of each other, so trying to join them with bondo... well lets just say it will be a waste of time and money....
Old 07-13-2005, 09:21 AM
Yep, no way, no how. If you wanted to "mould" ANY panels together you would need to weld them first and make them "ONE". The bed and cab would be even more complicated, as Bondo king said, they DO move quite a bit independed from one an other. Even "just welding" would produce disaster.
Old 07-13-2005, 03:08 PM
The cab sits on rubber mounts to cushion the vibrations from the frame and the box is bolted directly to the frame so both of these assemblies will flex and move at different rates. The box would need to be rubber mounted or the cab would need to be mounted solid, then both would need to be joined with some inner structure before the external sheetmetal is blended/welded together. Ford made some unibody trucks in the mid 60's and even them were known to crack where the box joins the cab. A full roll cage would help stiffen the assembly . This can be done but you're looking at a fairly large job to do it right. I've seen full sized blazers and broncos converted into pickups. Bob
Old 07-13-2005, 05:02 PM
VWFan's Avatar
Farfegnugen
Last journal entry: logo fun!
Or you could find and old 62 Ford I-beam truck. They were unibody trucks! So the bed and cab were one unit.
Old 07-13-2005, 05:17 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
dodge or Chrysler made a unibody like that too
you would have to do alot of reconstructing just to close that gapatosis
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 07-13-2005, 10:38 PM
crzy4507's Avatar
95Ranger
thanks
hey ppl... thanks for yur help.... if it werent for this site id probably be bomdoing it right now and crying later... lol... thanks again and im sure ill be back with more questions
Old 07-14-2005, 02:50 PM
Have Gun, Will Paint
I saw a "unibody" fabercation on a Nissan truck at a lowridershow once.......The cab and bed were molded together making it seem like one solid peace.....I dont' know exactly how they did it, but I'm sure welding was invalved........also they molding in the canapy to the bed and cab too
1988 chevy s-10 blazer, and i want to put a 327 in it. comments, good idea bad idea. 1969css Introduce Yourself 1 12-22-2004 06:18 AM
Q-Jet Metering Rod Idea Silver_Camaro Engine 6 09-16-2003 02:48 PM
Whacko Idea! Need transmission unstable Transmission - Rearend 5 06-26-2003 09:51 PM
Idea for a new carb...? Bartman39 Engine 5 05-13-2003 06:13 AM
Trunk idea Wmarden Interior 13 11-07-2002 12:11 PM
