The new and improved caddy - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2004, 09:40 PM
53fordguy's Avatar
Junkyard Kustoms
Last journal entry: update after a long time
here she is again....
Name:	car 0062-0 copy.jpg
53 fords rule!
Old 11-21-2004, 04:18 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
dropped or photochopped?
Mike
Old 11-21-2004, 08:21 PM
Novaman78's Avatar
Kill It & Grill It
Last journal entry: New door panels
Looks to me like the tires would rub.
Old 11-22-2004, 12:59 PM
crazygutgut's Avatar
I wanted an egg-salad sandwich
p shopped...
the edge around the tire is not smooth
The bolt pattern location is IDENTICAL on each wheel (he used the same tire for front and back)
by the fro t wheel there is a "white" spot right where the body meets the front skirt
plus if you look at the front and rear of the photo where the curb is, you can see the tell tale signs of a "patch" to blend in where the car was lowered...
the lights look like they alpha channel was adjusted
you know, we have a "forum" for this its called the "before and after virtual kustomz" thread...
still looks cool...
Old 11-22-2004, 02:09 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Someone has a hell of an eagle eye
Old 11-22-2004, 04:59 PM
New Member
And the plate was blackened out.
Old 11-22-2004, 08:03 PM
53fordguy's Avatar
Junkyard Kustoms
photochopp definite
but the wheels are like that no plates on the front and the wheels do rub since there 225/65/16's instead of the stock 195/75/15's its not far from stock....
53 fords rule!
Old 11-22-2004, 08:19 PM
I dun learned sumthin
Ya know that looks kind of real but something about the way those tires look doesn't fit. Also if you look at the pavement it looks like the rear tire is closer than the front. I don't know.
Old 11-23-2004, 09:51 AM
its amazing to me that your lug nuts are in the same position... also the tires do look odd. Do they stick out from the side? Plus the photo you have of that car in your gallery has a different set of wheels...
but if you say its real i'll believe ya'...
Old 11-23-2004, 05:15 PM
Novaman78's Avatar
Kill It & Grill It
Look at the picture he first posted. Look at the front drivers side tire there is a very faint line that goes across the picture in the outline shape of a car. ANybody else see it? i will try to highlight it
