New Intake Manifold/Carb now sputters - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-29-2013, 02:26 PM
dub's Avatar
dub dub is offline
Last journal entry: Time to drive..
the carb is brand new. out the box
  #17 (permalink)
Old 01-29-2013, 03:20 PM
71nova355's Avatar
I would say since you just changed the intake and carb the problem lies there not the thermo stat. I bet you need to check your accelerator pump linkage and make sure that gas starts squirting the instant the throttle blades open. sounds like its getting air from the blades opening and then following an instant late with fuel. make sure both promary and secondary blades are set equally and keep them that way. only ajusting both equaly if need be. the transistion slots should only just barely show under the carb below the throttle blades. your pump linkage should have a small amount left in it at full throttle so you dont prematurely wear out the plunger or pump. but it should also be set like .020 from actually squirting gas out. lol like the linkage should be just barely touching the pump arm and you can look down the carb when you apply throttle by hand and make sure that gas and air comes on together. also start with the fuel air screws 1-11/2 turns out and adjust from there with a vacuum guage getting the highest vacuum reading you can and the fuell mixture screws equally turned. what power valve do you have compared to vacuum reading? hang in there bud you got this. also are you running a fuel pressure regulator? and your floats are set right? Ive read double pumpers prefer single planes but ive seen all kinds of combos work and work good so that shouldnt be the problem. Have you tried a spacer? I just swapped from a open spacer to a 4 hole and I can definitely feel the better low end response. Although I have a single plane so maybe an open would give you more plenum area? idk oh you can also buy a set of colored pump cams and that will change the amount of pump shot sent to the squirters. maybe larger squirters would get fuel there faster too. you have plenty of room to grow before needing a bigger 50 cc pump shot too. Even new out of the box tho the carb should be checked thoroughly and set to spec.
  #18 (permalink)
Old 01-29-2013, 11:16 PM
dub's Avatar
dub dub is offline
Ok, well.....Feel kind of dumb. But have no problem admitting my faults...
I put the thermostat in backwards....Yup....sure did. I was on such a hurry because I was on limited time. So, that problem is fixed. That's my karma for not putting a new one while I was doing the swap.
As far as the sputtering, I adjusted the ratio screws. The process i used was basically set them all the way lean, then turning them 1-1/2 turns to rich. I test drove it and it much better. However I need to see what the total timing is and adjust more from there.
Ill update the page when I am able tomorrow.
Oh yea and by the way I still feel dumb about the thermostat. But whatever.
Thanks for all the replies.
Mike
  #19 (permalink)
Old 01-29-2013, 11:36 PM
vinniekq2's Avatar
If thats the only mistake you ever make then we will all bow down to you,,,lol. Things happen ,and the day continues on anyways
keep it fun and interesting
  #20 (permalink)
Old 01-30-2013, 02:05 AM
71nova355's Avatar
scratch my last post then...lol
now I feel dumb
  #21 (permalink)
Old 01-30-2013, 07:38 AM
dub, The best way to adjust your carburetor is with a vacuum gauge. Just hook up the vacuum gauge to a manifold vacuum source. Then adjust your idle mixture screws out until you have the highest reading. With the RV cam start out with about 12* initial and 24* mechanical (distributor weights). If it is a stock GM distributor untouched it will probably add 25* that will be fine. Total will be something like 37*. Don't add no more than 10-12* vacuum advance. Crane has an adjustable vacuum advance can kit, Crane Vacuum Advance Kits 99600-1 - SummitRacing.com that will fit the GM HEI. This also includes an advance curve kit to bring the mechanical advance all in by 3000 rpms.
  #22 (permalink)
Old 01-30-2013, 08:37 AM
carb and intake
Yes, change out the thermostat first to eliminate that as a cause. I would also advise you to run a simple check for any vacuum leaks around the manifold and carb with a can of carb cleaner. Just to eliminate a vacuum leak as a possible cause. Then I would look more deeply into the adjustments on the carb, specifically the secondaries. It may be dumping way too much fuel initially causing a hiccup before the engine can catch up with the fuel flow. A recurve kit on your advance will probably help as well. Just a thought, with a stock convertor you may not be building enough RPM's directly off idle acceleration to allow a complete burn of the fuel entering the chambers. Good luck
  #23 (permalink)
Old 01-30-2013, 01:25 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
You can disconnect the actuating arm to the secondary linkage And drive on the primary and see if the bog is still there! if it is take care of the primary bog before hooking up the secondary's! Then hook up the arm and test the secondary's! Unless your carb literate Its the easier way for a novice on carbs to start!
Jester
The Following User Says Thank You to painted jester For This Useful Post:
vinniekq2 (01-30-2013)
  #24 (permalink)
Old 01-30-2013, 04:07 PM
I wonder how the 650 DP runs on dub's car now that he has the temperature back to normal. Hope everything worked out without anymore problems.
  #25 (permalink)
Old 01-30-2013, 04:47 PM
carb
Yeah...I'm betting that took care of most of it. Havent heard from him since he fixed it...could be a good sign he's out tearing up the streets and has forgotten all about us...lol
Carb/intake manifold swap 305 Chev Tigerjohn Engine 10 07-25-2010 04:17 PM
Intake Manifold and Carb Ozz1967 Engine 9 12-29-2005 12:34 PM
4-71 with intake manifold and carb chevyhotrod Engine 3 08-02-2005 01:22 AM
Spacer between carb and intake manifold?... doc_rage Hotrodding Basics 2 02-06-2004 07:40 PM
carb/intake manifold 1969 CAMARO SS Engine 2 06-17-2003 02:20 AM
