-   -   New Intake Manifold/Carb now sputters (http://www.hotrodders.com/forum/new-intake-manifold-carb-now-sputters-228937.html)
dub 01-29-2013 12:12 AM
Hey guys,
I have a 72 Chevelle with a 383 Stroker. I just put on a new Holly Double Pumper, 650 CFM with a Air gap dual plane edelbrock intake manifold.
Runs great, but when I punch the throttle, it sputters and then kicks in, if Im at a stop, I punch the gas and sputters and nearly dies. But then catches and takes off. Any Ideas? Did I not tune it properly?
Timing is set at 12 degrees advance.
Next issue is that the motor under heats. Before the swap, it ran at around 190 degrees. Now it runs at 100-120. If I stop, it heats up to around 190, but then when I get going again, the temp rapidly drops back to 100-120...
Bad thermostat?
Any suggestions/troubleshooting is helpful.
Thanks,
Mike
vinniekq2 01-29-2013 12:17 AM
post the stats of before and after. What was the carb and intake before,how did it run,why did you change it? The 650 is way too small but should work great for idle to 5k
dub 01-29-2013 12:20 AM
Carb before was a 600 CFM edelbrock. 1405 manual choke.
Intake manifold was holly street dominator, single plane, post 82 with EGR valve spot.
And how is the 650 way to small?
vinniekq2 01-29-2013 12:30 AM
I would use a 750 on a moderate 350 cube engine.Most 383s are higher out put and you did indicate it was in a chevelle,I was guessing it made some power.
If you used a street master before then you must have been looking for gas mileage?
vinniekq2 01-29-2013 12:33 AM
correction street dominator,low rpm intake too,not as low as street master. I had a street dominator on my corvette when I bought it. The car mad 205 horse power with that intake,measured on a dyno-jet dyno
dub 01-29-2013 12:45 AM
I primarily changed it out because I didnt like the way that the carb was running. Wasnt happy with the product, and it was borrowed. (had to give it back)
As for the manifold, It had two spots for a EGR valve, so it needed two blocker plates. I could also tell that it was restricting the hell out of the motor.
And I did specify that it was in a chevelle. (i double checked)
Once I put everything on, it ran great. I reused the thermostat, prolly a bad idea, but it didnt give me any issues prior to the swap.....
vinniekq2 01-29-2013 12:51 AM
What is your total timing(@3,000),cam specs/CR,exhaust, even a meek 383 should be at least fun to drive.
The biggest issue is matching the parts,,,combination,combination
then tuning
you need to provide more information please
dub 01-29-2013 01:02 AM
Ok Ill start from the top just so I dont forget anything:
-1972 Chevelle Malibu
-350 block, bored .80 over with a stroker kit.
-Stock heads
-Long tube headers
-Flow master exhaust
-Cam is a mild RV cam. Im not sure of the duration. Very mild though, just above stock.
-Air Gap Edelbrock Intake Manifold
-Holly 650 DP Carb
-Turbo 400
-Stock Differential
-Floor Shifter
-HEI Ignition
If I remember correctly, the total advance is between 32-36. Ill have to double check tomorrow.
I think thats it as far as performance mods are concerned.
Let me know if you need any additional info.
Mike
cdminter59 01-29-2013 01:06 AM
I would change thermostat first to eliminate that as a problem. I have read a lot of post with the same problem of hesitation when using the Edelbrock RPM AIR GAP. It is not a good intake to use in cold weather so with the temperature running so cold that is probably the problem. If you can get the temperature up to 190-195 it will probably run better. Experiment with the timing try setting the initial at 16-18 degrees. You will have to limit the mechanical advance to 18-20 degees. What are your camshaft specs? What distributor are you using? Read this Wiki article on setting your HEI and timing. Also there is a section in the article on adjusting the transfer slot on Holley carburetors. Increase the initial timing and close the front throttle plates. http://www.crankshaftcoalition.com/w...EI_distributor. BTW you will need a timing light with advance.
dub 01-29-2013 01:22 AM
As far as the cam specs, Im not sure....I dont remember.
Total advance is betweem 32-36, Ill have to double check.
Ill change out the themostat tomorrow and see if that helps..
Thanks for the help guys.
Mike
painted jester 01-29-2013 01:33 AM
Your right the air gaps start to frost in the plenum and carb venturies about 40 degrees! In Michigan it even freezes the throttle shafts on cold days stuck at speed !!!! Not a good thing :pain: Its a warm weather intake there should be a warning on the box when a person goes to buy one LOL
:eek:
Jester
ap72 01-29-2013 12:29 PM
-Stock heads
-Long tube headers
-Holly 650 DP Carb
-Turbo 400
-Stock Differential
-Floor Shifter
-HEI Ignition
Mike
".080" over"?! are you sure? That's going to lead to a LOT of problems.
The timing has already been mentioned.
And for that mild combo that 600 edelbrock is a MUCH better match, though it may have needed tuning and/or cleaning.
vinniekq2 01-29-2013 12:31 PM
RE:
(The stock gears and stock low stall torque converter is not going to be very friendly to getting crisp throttle response with a double pumper carb. Just too much throttle, too fast.
Recurving the distributor advance curve will help. More initial at idle always helps throttle responce.)
please explain this? a 650 DP is extremely responsive,even on a 283 with 3.08 gears?
ap72 01-29-2013 12:40 PM
Originally Posted by vinniekq2 (Post 1640122)
RE:
That depends on how it is tuned. He may have way too much coming in from the accelerator pumps, or too early, or not enough, or too late, or too long/short duration. The joys of running that much pump on a heavy car with stock stall and mild gears...
painted jester 01-29-2013 02:04 PM
Is the carb new out of the box or used? If out of the box no tuning except basic. it should work very well and be pretty snappy on your combo! If its used it may have been tampered with! to match a different engines demands!!!
Jester
