New to this, just looking for advice and knowledge - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2010, 01:48 AM
Ok, i'm clueless when it comes to transmissions and rear-ends. I'm looking for something to put into a Nova that could handle 500HP. I'm in the process of getting the car ready before I get a crate engine and trying to learn as much as I can in the process. Any advice or suggestions would be appreciated. I've got a TH350 Tranny and have no idea about anything to do with the rear-end. I was thinking about going with a 700R4
Old 02-11-2010, 02:28 AM
I don't know. With that kind of Horsepower you might want to step up to a t-56.
http://www.chevyhiperformance.com/te...ion/index.html
Old 02-11-2010, 06:01 AM
big gear head's Avatar
High Performance Rear Ends
Your '74 Nova will have the 8.5 10 bolt rear end. This rear end can be built to handle 500 HP. You need a 30 spline Eaton Posi and a set of 30 spline Moser axles. If you plan on putting slicks on it then you need to weld the axle tubes. http://www.nastyz28.com/forum/showth...ing+axle+tubes Read this. A good rebuild with quality parts and correct set up will make it strong enough.
Old 02-11-2010, 06:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A TH700R4 or TH2004R can be made to handle 500HP. But it'll cost you accordingly.
A TH400 would be the least expensive way to go, but no OD. There are Gear Vendor OD add-on units, also expensive. I'd pass on a TH350. It can be made to handle 500 HP, but would cost more than doing a TH400.
You didn't mention torque converters, but that will be a vital part of the equation when you get that far.
Besides the 8.5" diff you now have, there are several manufacturers that have 12-bolt diffs (OEM 12-bolt units are going to be awfully high, and hard to find for no superiority in strength), Ford 9" and even Dana 60-type diffs/housings available. Again, for a price.
The advice to use the 8.5 "corporate" rear end is sound. The weak points can be corrected and the diff will then be good to go @ 500HP.
Hooking that 500HP to the pavement is another thing- Nova's aren't known for having large wheelwells out back, so plan on rolling the inner lip back and possibly doing more 'surgery' as needed.
A lot of guys will just bite the bullet and install mini tubs and relocate the shocks and/or springs to provide the room for some serious meat.
There are a lot of aftermarket parts for helping the Nova hook- you'll get more acquainted w/them as you move forward.
Depending on how much time and effort you want to put into the back half for traction, you could get by w/less- but careful measurement of the rear wheel offset/backspacing will be necessary in order to fit as much tire as you safely can.
195/75-14 was standard, I believe. About the biggest rear tire that will fit w/o cutting is 275/60-15 on 15x8 wheels with 4.5" of backspacing. These were Rally wheels, and will barely rub under some conditions.
But all sorts of things can alter this, including worn or sagging springs mostly- but also body mounts- actually ANY worn rubber suspension components for that matter, collision damage/repair, modifications, etc.
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
