-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   new kobalt- tank is hot (http://www.hotrodders.com/forum/new-kobalt-tank-hot-167999.html)
vintagecar 11-06-2009 07:20 PM
Maybe this is normal, but my new kobalt compressors tank gets very hot. More so on the top than the very bottom. The top of the tank you can't put ur hand on it for more than a second. Is this normal or is something wired wrong, or wrong with the compressor?
NEW INTERIORS 11-06-2009 07:38 PM
How hard are you running it ??? :sweat: Are you letting it kick off ??? :sweat: They will get hot.. :pain:
vintagecar 11-06-2009 07:44 PM
This can be hot from just a fill up or running pretty much constant. It was hot from the first time I filled it up. Everytime it fills up or just runs the tank is hot.
NEW INTERIORS 11-06-2009 07:59 PM
Not sure but mine get pretty hot,, We have some very hot day's here in the south.. I work mine pretty hard everyday.. :sweat: :drunk: not sure why yours is getting so hot.. :confused:
vintagecar 11-06-2009 08:25 PM
Well if your's gets hot then maybe it is normal?
weirdbeard 11-06-2009 08:58 PM
Most run pretty hot.. The pumps make a good bit of heat and just the air compressing in the tank makes heat. Not being able to hold your hand on the tank seems to hot. Unless you have a sensitive hand. :D
vintagecar 11-07-2009 06:27 AM
real funny! :D
