New LEDs for the wrecked dodge - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2012, 02:15 PM
I'm planning on installing led lamps for my 38 dodge that was in an accident few months back. Wanted to know if anyone has done it without any problems. It's 12 volt system leaving the front headlights and marker lamps alone just putting led's for the back tail lights and a 3rd brake light!! Thanks Scott.
Old 12-07-2012, 07:28 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
LED lamps are available from Super Bright LEDs to replace standard automotive lamps. Use red LEDs for taillights. There is a lot of junk for sale so be careful who you by from. Pep Boys sold them but I'm not sure if they still do.
Due to the reduced load the turn signal flasher will need to be replaced with a flasher designed for the LED. Speedway Motors - Street Rod Parts, Race Parts, Ford Flathead Parts, Sprint and Midget Racing Parts, Pedal Car Parts The LED flasher will work with standard lamps combined with LEDs.
vicrod
Old 12-07-2012, 08:07 PM
EOD Guy's Avatar
Superbrightled sells the flasher also.
Old 12-08-2012, 09:39 AM
ogre's Avatar
the 'Duracell Project'
custom or 1157 replacements?
i used 9 led marker lights for tail lights in the back of my 58
2 tail light and 4 brake/turn, then i added the led strip for a 3rd brake light in the trunk gap
while i was in there i add 2- 3mm plate lights
the ezwire harness i used had the led flasher in the panel
brake and tail
brake only
LEDS Again........R Front Turn..... hotflattie Electrical 3 03-30-2012 02:06 PM
LEDs on - help with the diagram darom Electrical 1 08-11-2007 06:55 PM
How much faster do LEDs illuminate??? Bryan59EC Electrical 19 07-11-2007 08:03 AM
Blue dots and LEDs don't mix!!! willys36@aol.com Electrical 21 05-09-2006 11:16 PM
changing dash lights to LEDs need some help mickey1031 Electrical 4 10-18-2005 08:55 PM
