Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New Life OLds
Thread: New Life OLds
Old 09-22-2002, 02:02 PM
roys63's Avatar
roys63 roys63 is offline
Post
The olds 455 will go right in with most of the 307 brackets for alt etc. and some longer belts. the wiring will be same for the most part for the starter and senders, etc.you will need to change the exhust pipes they will be to short , i don't remember if the 307 manifolds will bolt to 455 heads, but in the long run i think the olds will be cheaper to install.And a lot more Power!I am sure someone will give you more info on this.
