Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New Life OLds
Thread: New Life OLds
Old 09-22-2002, 03:13 PM
dallam1 dallam1 is offline
Post
Details, details. We need more of them. Yes, the 307 exhaust manifolds will fit the 455 heads but you will have to use the 455 x-over pipe but it will perfectly connect to the 307 manifolds. The engine will fit perfectly on the 307 motor mounts but the engine will be about 1 1/2" higher so if you are running it in a G-body, you might have to "section" the a/c. All in all it's a great and worth while project. I could give you more info if I knew more details.
