New master cylinder question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2003, 10:44 AM
Post New master cylinder question
I just recieved my new master cylinder and noticied there are 4 ports on it. Two on each side. Do i just plug two off? What type of plug?
Old 03-07-2003, 03:53 PM
Dave E Shank's Avatar
Talking
HEY BRIAN: I would use brass with teflon tape or other thread sealer. The MC threads are iron and rough and not always dimensionaly stable, which means they could leak. Call manufacturer and ask them, I am surprised they didn't furnish plugs <img src="graemlins/nono.gif" border="0" alt="[nono]" /> DAVE
Old 03-07-2003, 03:55 PM
Post
I found my plugs. They almost look like a bleeder. When you tighten down the center screw it makes a seal. Ever see these before?
Old 03-08-2003, 01:18 PM
Tazz
Post
What is the MC supposed to fit? I have not seen one with 4 ports before, is it for a newer car? What kind of valve are you using? Does the porportining valve match the MC? Are you running disc/disc or Disc/drum or drum/drum brakes?
Todd
Rat Rods Rule!
Old 03-08-2003, 02:31 PM
Post
not sure what it is for originaly. Its definitly for an older car. I have disc/drum brakes. Its an aftermarket adjustible porportining valve.
Old 03-08-2003, 03:26 PM
Talking
Master Power Brakes at www.mpbrakes.com sells a master cylinder with both left and right ports.. They have an informative web site. HOPE THIS HELPS... DAVE
