dsmithcae,
Do you know what the proper position of the oil adjustment screw (juki 241hs) for the hook reservoir might be? The manual states that oil flow is increased when the screw is turned in (cw) and flow is reduced when the screw is turned out (ccw). Based on the the design of the screw, this seems counter intuitive to me. The manual does not specify any "factory" setting either.
thanks
