Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New member from Alabama
Old 01-03-2013, 10:26 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Grumpy Old Goat Herder
Originally Posted by 64falconsix View Post
Bill ,thanks, I run a stock c/4 with a 3.20 gear, I think the car weighs in around 2,700 without driver. I have made a few passes untuned and went 10.57 at 61 M.P.H. in the 1/8th with a bit of wheel spin. not a barn burner but enough to have a little fun.
With more info (shift RPM and tire diameter and your RPM going through the traps) I could probably recommend a gear ratio to get you well into the nines in the eighth, but you wouldn't want to run the quarter mile. Also, you might think about using a better tire, at the track.
