-   Introduce Yourself (http://www.hotrodders.com/forum/introduce-yourself/)
-   -   New member from Alabama (http://www.hotrodders.com/forum/new-member-alabama-227920.html)
64falconsix 01-03-2013 08:23 PM
Old school 64 Falcon 2 dr sedan powered by a Tri -Power inline six. Hoping to both contribute and learn from this site.
69 widetrack 01-03-2013 08:27 PM
Welcome aboard, lots of good information here...have you got any pictures? Would love to see some of the Tri-power inline six.
Ray
64falconsix 01-03-2013 08:45 PM
Tri Power 200
http://i305.photobucket.com/albums/n...es64engine.jpg
64falconsix 01-03-2013 08:50 PM
Tri-power 200
Thanks Ray,.........200 cube .040 cast pistons A.R.P. bolts, balanced, comp cams 260/ .440 , billet double roller timing set, S.I. stainless valves ,comp and crane valve train, decked, Milled and ported head, clifford header , street strip D.U.I distributor, Offy tri power with 3 weber I.T.C. 34s .
69 widetrack 01-03-2013 08:51 PM
That is cool...any other performance done on the internals? Or anything other modifications,,,love the looks of that, it's something you don't see every day.
Ray
69 widetrack 01-03-2013 08:52 PM
You posted while I was posting, thanks for the update...any pictures of the whole car?
64falconsix 01-03-2013 09:11 PM
64 falcon
This pic is a couple of years old , the 13" slots are now gone and she wears 14" x 7" american racing outlaw ii with 205/70/14s
http://i305.photobucket.com/albums/n...psa148ecbb.jpg
69 widetrack 01-03-2013 09:16 PM
Beuatiful car, I love the slots, kinda period correct. I'm not known to be a huge Ford fan but have always loved the Falcons and Comets, very nice looking ride and clean as well, how was the body, it sure looks great in the picture.
64falconsix 01-03-2013 09:36 PM
I have had to replace both full floorpans ( due to leaking cowl ) and have the typical falcon / mustang problem problem areas, door corners, cowl and rear fender lip but for the most part in fair shape for it's age. I will tackle the doors first, then the cowl and save the rear fender lips for last.
Charlie
69 widetrack 01-03-2013 09:39 PM
Well the car does look good and well worth it, I don't know how much experience you have but if you need any information on paint and body, I'd be happy to help.
Ray
WDCreech 01-03-2013 10:01 PM
Originally Posted by 64falconsix (Post 1630325)
First off, let me say that is very impressive! What transmission in it and what rear-end gear ratio? Do you know the total weight of the car and do you plan on taking it to the strip, if only to see what it will run?
Bill
64falconsix 01-03-2013 10:10 PM
64
Bill ,thanks, I run a stock c/4 with a 3.20 gear, I think the car weighs in around 2,700 without driver. I have made a few passes untuned and went 10.57 at 61 M.P.H. in the 1/8th with a bit of wheel spin. not a barn burner but enough to have a little fun. The roadrunner had a fresh 318 with a RV cam, edelbrock intake and carb and full length headers.
69 widetrack 01-03-2013 10:17 PM
Still respectable for a six, I like the fact that it'd not your typical small block 289 or 302...wouldn't be scared to open the hood at any A&W.
64falconsix 01-03-2013 10:40 PM
Yeah ....to say the least the cruise nights are interesting. The little six gets plenty of attention.
WDCreech 01-03-2013 11:26 PM
With more info (shift RPM and tire diameter and your RPM going through the traps) I could probably recommend a gear ratio to get you well into the nines in the eighth, but you wouldn't want to run the quarter mile. Also, you might think about using a better tire, at the track.
