New Mickey Thompson valve covers and PCV - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 03:14 AM
Sir-x-Loin's Avatar
The kid is the man.
Hey all,
I have decided to switch over from an open breather to a PCV system. I got a cheap pair Of Mickey Thompson Valve Covers on eBay. I have never ran these valve covers or used a pcv system on my truck.
valve covers - http://www.ebay.com/itm/290659264328...e=STRK:null:IT
PCV valve+ breather - http://www.ebay.com/itm/310332738247...e=STRK:null:IT
Oil Cap - http://www.ebay.com/itm/390375794110...e=STRK:null:IT
I have a few questions. What is the best way to get the knock outs out? Will this oil cap work? On the PCV grommet, it looks to be closed, is this a poor mans baffle? Will I need a pcv baffle?
Thanks.
Old 01-22-2012, 09:06 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
I think you need to cut out, the knock out holes
dont know if the cap will work
the grommet will need to be cut if you want it to be used as a breather, not just a oil fill plug
* I could be wrong on any of this, maybe someone else will speak up
Old 01-22-2012, 10:15 AM
Sir-x-Loin's Avatar
The kid is the man.
I've never had M/T v.c's before. I read about people using a Uni-bit or a step bit and even wacking them out with a hammer and socket. The oil fill notched area is mainly what I have questions with.
Thanks.
Old 01-22-2012, 07:20 PM
tnovot's Avatar
I have these same covers on my T-Bucket and I used a small drill bit to drill several holes in a circle around the circumference of the knockout. Then I knocked it out and used a dremmel tool and file to smooth the edges and used a breather with a rubber grommet.
Terry
Old 01-22-2012, 07:54 PM
dinger's Avatar
A short length of pipe about the same size as the hole, using the pipe as a backer where you are gently tapping the piece to remove with a small hammer. Place the pipe on a firm surface, the valve cover on top of the pipe, tap the knock out, out.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
SBC Mickey Thompson valve covers josh woloshyn Hotrodding Basics 2 10-30-2009 07:42 PM
Mickey Thompson ET Street chevy_power427 Suspension - Brakes - Steering 4 10-29-2007 07:22 AM
Mickey Thompson malc Hotrodders' Lounge 15 09-14-2006 05:37 PM
Mickey Thompson VC grommets M/T 71-longbed Engine 1 10-24-2005 03:57 PM
Mickey Thompson?? kitkar Hotrodders' Lounge 8 02-18-2004 10:36 PM
