New mild CSB 360 build advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2013, 02:25 AM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
Well im building a mild 360cid, wel in finland it is a pretty hot street engine.
Engine specs
11.4cr
4bolt 350 block .060 over
trw hyper small dome pistons
6 inch eagle rods
eagle cranck std stroke
Mec roller cam xtreme energy 12-773-8
050 in254 ex260
Cylinder heads
AFR 210ccintake 65cc chambers
Carb is a AED ho 850cfm
Intake manifolds i got 3 to chose from if there is something better out there tell me? AFR manifolds are out of my budget
The team g is closest to port sizes
The super victor or Team g or a holley stripdominator?
Old 02-18-2013, 10:19 AM
vinniekq2's Avatar
victor Junior,thats a small engine for a super victor.The heads are middle of the road.I would have considered the super vic with 227 cc heads and I would also want more cam with a super vic
Old 02-18-2013, 03:19 PM
dont think the vic jr will do better than the team-g ?
Old 02-18-2013, 03:36 PM
vinniekq2's Avatar
I use a vic junior on my 434.never had much luck with weiand so I quit buying their items.
The vic junior works well on my 434
I Have 227 dart heads and a bigger cam,1 7/8 headers
lood at my thread and listen to it,thats my mild street engine
and others posted their street engines on the same thread
Old 02-18-2013, 04:15 PM
The 434 sounds nice! how much hp do it make? max rpm?
Old 02-18-2013, 04:27 PM
vinniekq2's Avatar
It revs past 7k
the peak hp was at 6470.
The power is awesome.I will post dyno figures after its on a chasis dyno. Engine dyno HP doesnt mean much as you are using dyno headers,no drive belts,cool air gets to the engine as no engine bay or hood, dyno carb, cooling system is bigger than the car,,,,etc
I want to see what a heart breaker Mustang chasis dyno says... will be awhile.
PM me if you need more details
Old 02-18-2013, 04:30 PM
are theese the right flow nr for your 227cc heads?
.200" 158 - 117
.300" 209 - 149
.400" 257 - 182
.500" 293 - 211
.600" 302 - 220
.700" 309 - 226
.800" 314 - 232
Old 02-18-2013, 04:45 PM
vinniekq2's Avatar
My flow numbers are a little better than that. The Jefflukovich shop tidied them up a little
and you need to add 100.I think that was a typo on your part.
My intake max flow is 327 cfm from a flow bench.My cam is 640 lift on the intake side.I use shaft mounted rockers with 1.6/1.5 ratios
Old 05-26-2013, 12:37 PM
Engine specs
11.4cr
6 inch eagle rods
050 in254 ex260
Cylinder heads
I made a 11.800 pas @ the track 60 ft was 1.706 speed 189 km/h 117.74984mp/h car is 1650 kg 3637.627lbs
Old 05-26-2013, 02:49 PM
vinniekq2's Avatar
moderately heavy car,good pass for a street car.
Old 06-03-2013, 12:45 PM
Well my hijackers slows me down a bit and i drive it on Drive not a man valvebodyjust to get the times consistent its a bracket car. and it changes gears @ 5500rpm but it pulls hard from 6k to 7k so i supose i could get the times down but i cant go faster than 11.5 in my class
360cid CSB carb advice Scandinavian Engine 8 01-12-2013 01:26 AM
mild 454 build 454k1500 Engine 15 12-17-2012 08:57 AM
ready to build a mild 350 but need advice soon2be Engine 39 09-09-2010 09:33 PM
Help on mild 350 build.. Meangreen Engine 14 08-26-2009 07:16 AM
Mild 350 build... need help 350cruiser Engine 32 04-07-2009 09:29 AM
