New motor runs rough ,suspect timing - need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2006, 06:33 PM
Hi All,
Fresh SBC , car still on jack stands. Engine runs like a 4cyl ( bad miss )
I adjusted the valves and set the timing. When running I disconnected one
plug wire at a time. cyl's 1-4-5-7 were good and 8 & 2 were poor and 3 & 6
made no differance at all when pulled. So I tried a second set of known to be
good wires and got the same results , then checked the ohms on the first set
and they were ok so I put them back on. Everything is new so I dont think its
a defective part. I think I screwed up the timing somewhere along the way but cant figure out where. When I was setting the valves it was at #1 TDC
0-deg on the hub and both # 1 int & exh were closed ,so I dont think I'm off
by 180 because the rotor was pointing to the # 1 plug lug on the cap. I dont
think the valve adjustment is wrong because I've checked and readjusted
them five times in the last three days. I tried to get a flash light and mirror
into the #1 hole but there isn't enough room ,all I could see was '' up '' to
the underside of the head. Is it possible for the mtr to start and run (poorly)
while being a 180 out, or will it just not start at all ?
The mtr, is carburated and has a MSD ignition 6BTM & a pt # 8570 distr,
The plugs are autolite # AR3910 , they were hard to gap but I think I have
a consistant .048 gap on them. Also # 1 or # 3 cyl makes a funny noise
when the mtr is running, kind of like a spring is actuating a air leak ?
I've adjusted the valves five times , first to lose then to tight then in between
Its possible the tentsion isn't right but I highly doubt it, more like the phasing
is wrong ?? Anybody live in the Lake forest So Cal area and want some cash
for a house call ? cause I'm lost !
Thanks, Joe
Old 04-22-2006, 12:56 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Do a compression test. If its 180 out, it won't run. You sometimes get the #2 cylinder firing on the intake stroke which makes a nice gunshot up through the carb
It sounds like either it was a bad valve job or some rings are upside down. If you have spark and it runs on 6 cylinders, look to a compression test.
Old 04-22-2006, 12:58 PM
curtis73's Avatar
Wiki Edits: 16
Wait... did you set all of the valves at TDC #1? If so, that's your problem. You can only adjust a couple valves there. You have to rotate the crank to do all of them.
Old 04-22-2006, 01:03 PM
Classix_Lover's Avatar
Music soothes the soul
Last journal entry: Wiring finished finally
My thoughts exactly when I first read what he said, I was just like wait what?? You adjust the valves seperately, you may have adjusted them correctly to 0 lash on the #1 cylinder when both the valves were closed but like curtis said, you have to rotate the crank to set the other valves like the #1 cylinder valves were set where both are closed. Then repeat the process till you have all of them set correctly and try firing it again.
Old 04-22-2006, 03:04 PM
new motor runs rough
I used the '' Watson Guide to Happy Valves " which is #1 at TDC & do
exh, 1348 & int 1257 Then bring #6 to TDC and do exh, 2567 & int, 3468.
Now I'm going to readjust them one cyl, at a time - rotating the crank 90 deg
each time . I also changed plugs to a hotter one ,the first set were autolite
# AR3910 which it turns out is for use with compression ratios around 13-1.
I'll report after all the new plans have been tried. Thanks.
Old 04-22-2006, 09:19 PM
Ive been there
Upon my first engine rebuild I had the same problem where the motor ran but ran rough. I had all the valves set as close to right as i could get them and everything checked out good. That day i found out that a motor will run when it is 180 degrees out of time. It will run like **** but it will run. Before you go dicking with the valves and all sorts of other things. Try to rule out the simple things first. But the #1 Cylinder at TDC with the Dist. cap off. Mark where it is pointing then remove the dist. and turn it 180 degrees and reinstall it. I am confidant this will either sooth your thoughs of being 180 off or it will fix your problem.
Old 04-23-2006, 10:42 AM
Been there
I now am confident its not out 180 , got a visual of #1 piston at TDC
and the valves are closed & the dist, is pointing at #1. Now Im thinking
that there might be a vacuum leak where the intake meets the head on
the bottom floor side which could explain some of the oil on the plugs.
Thanks.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
BBC Timing Top Rod Hotrodders' Lounge 4 11-13-2007 11:48 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 02:35 AM
Rough idle timing 66chevy2ss Engine 6 08-16-2002 01:55 PM
BBC Timing Top Rod Engine 0 06-09-2002 09:29 AM
