New motor wont run unless the timing is way advanced - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-04-2011, 02:47 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
That's what i was trying to tell him in his other thread on the same subject. SBF - Wont run unless timing WAY advanced?? .
Cole
  #17 (permalink)
Old 12-09-2011, 04:34 PM
Did you ever solve this issue? What your describing is what Iam currently going thru on my 302 Roller install. One thing I did find is that my carter electric fuel pump was putting out over 8psi, and from what I've read, the 1406 Edelbrock carb like 4.5. psi
So I put in a FPR, but Iam still having issues.
  #18 (permalink)
Old 12-09-2011, 07:05 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
When you set your timing to normal setting hook up a vacuum gauge manifold side
try and start it & record the reading! Now do the same thing with timing set high try and see what the reading is before it starts! if vacuum reading is higher then your cam could be off or your lifters could be adjusted wrong.
When you primed the eng was oil flowing to all your rocker arms ?
Whats a dizzy? Do you mean distributor ? Im getting old
  #19 (permalink)
Old 03-30-2012, 04:12 PM
My 87 5.0 won't run unless timed to about 50 TDC
Need help for the experts My 87 ford 5.0 won't run at all unless timed to about 50 TDC... Tripple checked all the normal specs. Firing order , TDC and the marks on the damper are right, I removed the distributor and verified the one tooth off theory - I went as far as to yank off the timing cover and verified that the timing marks are aligned then changed the set anyway. Nothing works - I finally resorted to moving the spark plug wires all over one to where #1 wire is now on the #8 post. This is the only way it will idle - as it idles if I adjust the timing to attempt to retard it to anywhere normal it dies every time.
SBF - Wont run unless timing WAY advanced?? z-adamson Engine 9 01-02-2011 01:11 PM
40 degrees advanced timing to run kleen56 Engine 7 11-08-2010 09:35 PM
car wont start timing help please schottout Engine 2 10-20-2009 06:31 PM
Fresh motor wont turn over... DarknessSpawned Engine 22 04-25-2008 03:24 PM
motor wont fire 67bird Engine 17 01-19-2004 10:30 AM
