Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - new and need help building 383 stroker
Old 02-10-2013, 10:25 AM
marvinp84 marvinp84 is offline
im building a 383 stroker need some help picking out compression ratio cam and heads i wanna run afr heads forsure im also running a edelbrock pro flow xt fuel injection on this engine it has 44 lb/hr injectors rated up to 650 hp i wanna run around the 500 ft/lb to 500 hp rage the kit im getting is a cnc machined block scat rotating assembly flat top pistons if i run 65cc head ill be at 10:8:1 compression im also worried if that would be a bit high for pump gas as i wont allways run high octane fuel its going into a 71 chevelle with a 5 speed tremec manual trans and a 355 rear end use mostly for st/strip any suggestions as to what i should build this egine with cam head combo to meet my goal ?
