New Old Carburetor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2010, 10:29 PM
New Old Carburetor
I recently picked up a new in the box Edelbrock 1405 carb for a very good price. Thing is, it has a manufacture date of 12-29-97, making it 13 years old. It is in perfect shape. Should I be concerned about using this? Are there any parts that should be checked or replaced? Thanks.
Old 11-08-2010, 01:24 AM
DoubleVision's Avatar
A carb can sit in a box 30 years, be bolted on and run fine. The killer of carbs is when fuel sits in them for a time and it turns into trash and varnish. Or when they get high mileage and the throttle bores wear out.
Many years ago I was looking for a Quadrajet and a friend of mine had one. He removed it off a truck about 10 years prior. He drained the fuel out of it before it sat in his shop for those 10 years. I was in a hurry so I didn`t even bother to clean it I just slapped it on and it ran great.
If the carb`s been in the box and been kept out of the elements it should be fine.
Old 11-08-2010, 02:17 AM
the only issue you MIGHT have is some dried out gaskets... in which case a refresh kit should solve any issues.
Old 11-08-2010, 08:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would certainly try it as-is first. One thing that might take a bit of soaking in fuel to come fully back around would be the accelerator pump piston. But otherwise it should be OK.
Old 11-08-2010, 08:28 AM
Thanks for the advice. I'm just goign to bolt it on when the time comes (still working on the engine). It was too good a deal to pass up and like I said it is new in the box, was stored inside and looks perfect. Thanks,
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 01:13 AM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 07:03 PM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 04:36 PM
Re-jetting with 4 hole carb spacer? stinky jinx Engine 11 07-13-2005 11:11 AM
spacer plate what does it do? CurtisL Engine 5 11-02-2003 04:12 PM
