New/ Old dizzy tach output? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2011, 10:46 PM
On the old style HEI dizzy(80ish) there was a place for a tach wire.
On the newer style dizzy(97ish) there are 3 wires 2 i assume are for the hall effect sensor.
Is the 3rd a tach signal wire?
Thanks
Old 06-14-2011, 11:44 PM
Also if the tach is not ran off the dizzy one a 97 GM what sensor does the tack run off of? The one on the front of the crank shaft?
HEI dizzy help 88BIGchevy Engine 11 06-25-2010 08:03 PM
Oil in Dizzy?????? Rosewy Engine 5 05-06-2008 11:23 AM
dizzy set up g60winds Engine 4 02-15-2008 02:05 AM
setting the gap on a points type dizzy... makes me dizzy... JJ350 Electrical 6 04-04-2007 03:55 PM
setting the gap on a points type dizzy... makes me dizzy... JJ350 Engine 6 03-27-2007 04:33 PM
