Having a heck of a time trying to find a rubbing noise in the front end, but I found it. Seems that the caliper is hitting deep inside of the rim, so much so that you can see more rubbing on one side than on the other. . Wheels are after market 15" wheels with a 4" offset. Don't have any problem with the other wheel, but this one. Will fatter pads cause the caliper to move out to cause the hitting? It is a floating caliper (one piston on the inside). Short of making a 1/8" spacer is there anything else that I can do?
I agree. On my rears running 15's I had to take almost 1/8" off of the two raised "ribs" on the caliper. Swapping to 16's would have solved my problem, but if I were you I'd take an angle grinder with a course grit flap wheel to the top of the caliper.
:sweat:I took a look at the other wheel and it too has a slight interference (see pics); more on the drivers side as compared to the passenger side. The interference is where the pin just about comes through the caliper, in both wheels. I suppose it is a fault of the wheels, although the stock ones do not hit.
Grind it and then hit it with some high temp paint. I have had wheels that would not go on until I grinded the caliper down. On gm single piston rear calipers you can go almost 3/8. I have pictures at the house of a pilot kit(get for free with install/report) I needed to go a bit extreme on to fit the stock wheels on.
Make sure when you have your wheels balanced they put the weights on the outside.
Just a note here, in case you're buying new rims. There are also "pad offsets" that affect only the caliper clearance and do not alter wheel offset...
Russ
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
