New paint bubbling - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-10-2005, 01:54 PM
BarryK's Avatar
What did you miss?
you can't repair something without knowing the cause, unless you want to do it again.
The only thing that can cause a bubble that big is a gassing effect.
So when you carefully cut the top of the bubble off let use know when it stops and what you see under it and we can tell you what caused it.
Sealer would not have helped the problem you had.
When you cut the top of bubble off with razor blade we will need to know the following to help you.
What is stuck to bottom side pf paint , K36, acid, etc.
What is next item still on car, K36, body filler, etc.
What does it look like inside the bubble, clear liquid, rusty liquid, nothing.
If liquid stick finger in it and smell it.
  #17 (permalink)
Old 04-10-2005, 04:57 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
The photo is a bit blury but I can tell you the problem now that I opened it. What was underneath the bubble?
Drum roll........
spot putty.
I realized after I painted it I used the wrong stuff.You can see it at the bottom edge of the hole.
  #18 (permalink)
Old 04-10-2005, 05:10 PM
BarryK's Avatar
Good deal, that an easy fix, sand off putty and give leftover tube to someone you don't like!
  #19 (permalink)
Old 04-10-2005, 10:37 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Good advice. That stuff isn't even good for body putty on model cars. Toss it.
  #20 (permalink)
Old 04-10-2005, 10:47 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Right. I think everyone has experienced the red "toothpaste" early in their career. I can't believe they keep selling that crap. Guess that's why,People still buy it.
  #21 (permalink)
Old 04-13-2005, 02:50 PM
lamothe1's Avatar
You might go to chevytalk. com. They have a forum on body work and paint and there are some very knowagable people over there in fact a lot of the replies are form ex-body shop guys.
  #22 (permalink)
Old 04-13-2005, 03:28 PM
BarryK's Avatar
  #23 (permalink)
Old 04-13-2005, 06:20 PM
cboy's Avatar
Last journal entry: Finished
Well, it's a good idea...just bad product. Is there anything "high end" that works? And what's the alternative...get the filler straight as possible and then work out the craters, pin holes, and low spots with high fill primer???????
Always learning...and sharing what I've learned.
  #24 (permalink)
Old 04-13-2005, 11:40 PM
Get your filler work as straight as possible then skim the area with a coat of polyester glaze, this stuff is just a very fine body filler that spreads very thin and smooth to fill any heavy sand scratches and pinholes, etc. Final sand with nothing coarser than 180 before primer, I prefer 320 grit for the final sand. The less filling you need to do with primer the less chance of any shrinkage problems. Exception- Polyester primers can be used for filling some nasty imperfections, but with a urethane primer I wouldn't prime over any sand scratches coarser than 180. Bob
  #25 (permalink)
Old 04-14-2005, 02:15 AM
garretthes's Avatar
I spend a great deal of time on the chevytalk sight. Thanks.
  #26 (permalink)
Old 04-14-2005, 03:45 AM
dawg's Avatar
NAVY VETERAN
water in air line and humidity in the air will cause just that.
airconditioned paint booth a must in your location.
and of course water seperators for the air lines
  #27 (permalink)
Old 04-14-2005, 06:28 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
One thing not mentioned that would be obvious,
You didn't wet sand anything before painting did you?
I've seen bubbles where water was still in the filler before painting.
It's really hard to get it dry enough once wet.
I know this is a no-no but some people have done it.
  #28 (permalink)
Old 04-14-2005, 08:16 AM
Bee4Me's Avatar
Any of the catylized spot/finish are great. Most all the Evercoat products and designed for this type skim work. Sure they cost more,But as we can all see the results of the "cheap" stuff.
I understand what your saying about the moisture down South, But we been painting a long time without A/C.
  #29 (permalink)
Old 04-14-2005, 01:36 PM
cboy's Avatar
Do you hand block at this point or use your DA?
  #30 (permalink)
Old 04-15-2005, 12:48 AM
tiny bubbles
Originally Posted by garretthes
I did sand it well, just not down to the metal everywhere. I used K36 primer, no sealer. I used rattle can etching primer where the bare metal was showing through.
The rattle can etch is the culprit,guaranteed! Seen it happen.Etch must flash at least 30 minutes then maybe re skuff prior to prime.Trapped solvent/gassing out.
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 01:33 PM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 11:39 AM
New Paint is bubbling garretthes Body - Exterior 3 03-23-2005 11:39 AM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 07:31 AM
Need color/top ideas.... Cracker Red Body - Exterior 4 09-07-2004 09:14 PM
