New Paint Job ruined? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2005, 11:48 PM
camaro409's Avatar
YOu KnOw IT
hello i have no idea how to paint a car or anything that has to do with it..so with that being known i searched the knowledge base for hours looking for an answer that i can't find.. first my car was just repainted base-coat then clear while moving the car out of storage i ran over a can of spray paint that blew splats down the door what can i do to remove the spray paint off the car if anything?
Old 03-26-2005, 12:00 AM
tbirdscott's Avatar
stuff'n things'n whatnot
How old is your paint job? is it just a light mist on the new paint or did it actually cover it? I would say give it a couple weeks for your new paint job to dry pretty good and go over it with a buffer and polishing compound but thats just me, i'm sure one of the old guys here knows exactrly what to do
Old 03-26-2005, 12:38 AM
camaro409's Avatar
YOu KnOw IT
the paint job it self is about 4 months old ..its misted all over the bottom side of the door and the fender ..i was thinking about using rubbing compound and buffing it off too...but i wasn't too sure about it
Old 03-26-2005, 06:23 AM
cboy's Avatar
Last journal entry: Finished
What kind of paint was in the spray can, enamal?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 03-26-2005, 07:33 AM
302 Z28's Avatar
If the paint job has not been color sanded and buffed out yet, that may take care of it. If that has already been done you could use some solvent. Start with plain mineral spirits first. If that does not work move to lacquer thinner. Do not soak the area, wet a rag and wipe it quickly across the paint to remove it. If that doesn't work you will have to wet sand the area and rebuff. I know the lacquer thinner will soften the clear coat, but a quick light application should not hurt it.
Vince
Old 03-26-2005, 08:44 AM
I would take no chances.
Go to local auto paint store and get a clay bar kit $20.
If they don have one they can order and have it next day as long as the paint did not melt into the car paint this will take it off.
Old 03-26-2005, 07:56 PM
Just Got Yellow Paint Off My Dads New Black F 150 Use Small Amount Of Lacquer Thinner, Wipe It On Then Off Then Came Back With Number 6 Meguiars Cleaner Wax No Problem Looks Fine .
Old 03-26-2005, 08:02 PM
CLAY BAR, CLAY BAR use the clay bar. DO NOT use lacquer thinner at his point.
If you guys havn't found the magical clay bar you really need to get one. When I was repping I had people throw all kinds of problems at me "So, remove this and I will stock it in the store" They would walk me out to some God awful problem and say "Have at it". It failed me very seldom. I removed vicious water spots off of near new bc/cc, glass. DIRECT overspray off plexiglass windows! Urethane primer specs off fresh bc/cc and off OEM paint. We are talking year old urethane off paint, no problems what so ever. No need to even buff later.
Old 03-26-2005, 08:13 PM
Who makes that clay bar you guys are talking about? A few years ago we used one that I believe was Mequires and it was great. Then they changed something about it and it did not seem the same. I haven't used it since. I am interested in trying again.
Old 03-26-2005, 08:34 PM
Don't know who makes it but NAPA auto parts disributes one under part number 7260 in the MS line. It is a kit with a lubricant. The bars are 7261 (fine)and 7262 for med. I never used one side by side to see the difference. I can't understand being they are not "cutting" anything.
Old 03-26-2005, 08:43 PM
What do you mean by "the MS line"? Thanks.
Old 03-26-2005, 09:28 PM
"MS" is the Martin Senour line. I only mentioned it in case they don't have it in the inventory system they could order it for you.
Old 03-26-2005, 10:04 PM
Have Gun, Will Paint
McGuire's has a great clay bar.........and yes it works wonders
By the way..........sense your clear is well catalyzed you won't hurt anything by rubbing the over spray with a mild solvent.......you may have a haze after your done, but it will come right out with a quick buffing.
Old 03-27-2005, 04:47 PM
camaro409's Avatar
YOu KnOw IT
thanks all for the responses i'm going to use the ol clay bar sometime during the week
Old 03-27-2005, 05:08 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
I don't know squat about painting a car but I do know the clay bars work wonders. My brother cleaned up a similar problem on a beautiful black Buick GN.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Custom Paint Job? Trippie-Hippie Body - Exterior 8 01-30-2005 03:22 PM
Need color/top ideas.... Cracker Red Body - Exterior 4 09-07-2004 08:14 PM
how much can i accept to pay for a paint job? 79montecarlo Body - Exterior 5 10-26-2003 11:22 AM
Looking for Paint Job ideas.... Lonely Raven Body - Exterior 0 10-13-2003 09:06 PM
