New Pics of Grandmas rear end! Pattern ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2006, 03:00 PM
AMDAP's Avatar
CEO of The AMDAP Mulisha
Hey Guys! I think I've got the new carrier setup now. I'm just wondering if you guys think this pattern is acceptable. I know it might be a little bit high on the drive side, but it also looks like it should work to me...
Thanks for everything guys!
Old 03-07-2006, 07:05 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Going by the two pictures you provided, the first shows the idle side of the tooth being a little on the high side but within the acceptable range.
The second picture showing the drive side of the teeth, looks to be just right- and centered both ways on the teeth.
What is your backlash reading? If it's within specs, button it up.
Don't forget to break the gears in according to the manufacturer if they are new, used gears don't require a break-in period.
Old 03-07-2006, 10:41 PM
AMDAP's Avatar
My backlash is at 8 and 1/2 thousandths. It is supposed to be between 5 and 9. The gears are used, so I figured that was probably about the best I was going to get for backlash and a pattern. Thanks SO much M&M CUSTOM!
Old 03-08-2006, 01:59 AM
73oldsman's Avatar
"New Pics of Grandmas rear end" Hey!? Where's the pics of her rear end?
Old 03-08-2006, 02:07 AM
AMDAP's Avatar
I thought she might get offended if I put up the real ones...Geez that was messed up!
Old 03-08-2006, 02:37 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I've seen recommendations for used gears anywhere between 5 and 12 thousandths. I would say with that pattern and the backlash reading you have, with used gears, that you are good to go.
Old 03-08-2006, 03:10 AM
AMDAP's Avatar
AWESOME! This is the first rear end I have done. So I just had to make sure. Thanks for the input M&M!
Old 03-09-2006, 11:32 AM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
AMDAP just wondering how long it took you to set them up. I did a set last year and it took me forever I don't know how many times I took it apart
Old 03-10-2006, 12:40 AM
AMDAP's Avatar
I had to take it apart either 4 or 5 times. It really seemed like a lot more at the time. Once I seen that pattern I was pretty happy. Yet this was my first time, so I had to come on here and make sure it was acceptable. It took me longer to put the brakes (that my uncle took apart) back together I think. The rear end was way easier than I ever thought it would be. Just time consuming.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 02:44 PM
s-10 rear end smallblocked_S-10 Transmission - Rearend 11 06-17-2005 06:43 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 07:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 07:38 PM
