new pistons/rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2008, 01:20 PM
Don Meyer's Avatar
new pistons/rods
Can rods be pressed on new pistons cold w/o problems or do they have to be heated. How do you do it?
Thanks Don Meyer
Old 08-21-2008, 03:42 PM
Guy Hiltz's Avatar
I believe they need to be heated,take them to a shop and have it done properly,its not that expensive.
Guy
Old 08-21-2008, 03:49 PM
T-bucket23's Avatar
Wiki Edits: 26
I believe heating is the prefered method now. Long ago when i actually did machine work (early 70's) we would press them in. I dont think they do them that way now.
Chet
Old 08-21-2008, 04:19 PM
new pistons/rods
my machinist has a tool that allows him to add or remove them without heating , he's done several and had no problems .i know he's had it over twelve years .
never seen him put rod pins in refridgerator first either .
Old 08-22-2008, 04:54 AM
Last journal entry: PICTURE TEST
installation
There is a tool that supports the rods for doing them cold..IMO I don't like it, to much of a chance of cracking a piston. I know they say you can't using that tool but i think different.
Thats not a high dollar item at a shop. I charge like $25.00 a set to hang them if the rods are clean and ready to go.
Keith
Old 08-22-2008, 05:39 AM
Don Meyer's Avatar
Thanks for the replies. My engine builder was going to try to do it cold, but you all have convinced me that they need to be take them to a mach shop.
thanks - I always get good answers here.
Don
Old 08-22-2008, 01:51 PM
Don Meyer's Avatar
I called several mach shops & they say they never saw pistons/rods like mine.
My rod floats on the pin & the pin is a interference fit on the piston.
Neither mach shop had facilities to heat pistons only the rod.
Can I heat the piston w/a torch & press the pin thru?
Don
Old 08-22-2008, 07:40 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
What kind of pistons and rods do you have? Pins that press in the piston is a new one on me.
Old 08-23-2008, 07:26 AM
Don Meyer's Avatar
They are from a Corvair.......Don
Old 08-23-2008, 12:00 PM
rods
Silly us,,i guess we all were thinking small block chevy..
I have never seen that either. You will need to find a shop that is skilled enough to mic the pin, bore gage the piston pin bore and figure out the fit. Then come up with a way to shrink the pin (aka dry ice) or warm the piston enough for assembly.
If you run out of options in your area PM me. I might be able to help you out.
Keith
