Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New project 68 442 conv
Old 04-20-2013, 09:10 AM
mr4speed mr4speed is offline
Making more progress on this 442 with most of the bodywork done,final blocking of the poly primer almost finshed, then it will be coated with epoxy after the final sanding of poly. Once that is all in the epoxy it will come off the chassis, then all bodywork begins on the underside of the shell.
ID:	73340   Click image for larger version
ID:	73341   Click image for larger version
ID:	73342   Click image for larger version
ID:	73343   Click image for larger version
