New Project swap TH350 to 7004r - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2005, 08:50 PM
Parisienne70's Avatar
hi,
i have a parisienne 1970 4 door, 350 with th350, i buy a swap s10 1988 with 350 1977 blazer motor with 7004r 1991 s15, i want take the 7004r and put in my parisienne. i can make this ??? what i need for this swap and is hard to make ???
thank you
Éric
Old 11-28-2005, 06:18 AM
astroracer's Avatar
It all depends on trans length. The 700 will swap in, that is not the issue. You may have to move the trans crossmember to make it match up with the 700 mount.Just make sure you get all of the control hardware from the s10.
Your biggest headache may be the driveshaft. If you have a long tailshaft 350TH in the car you may need to get a driveshaft made to fit. Doing some measuring before the swap will clue you in to the mismatch.
Mark
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
What's needed for a th350 to a th400 swap? Fil Transmission - Rearend 2 09-16-2004 02:09 PM
700R4 to TH350 Swap in a 4x4 Torque Monster Transmission - Rearend 6 02-19-2003 06:40 PM
