Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - new rebuild sbc runs great in the driveway but...
Old 06-12-2004, 05:38 PM
tresi tresi is offline
It's always best to limit ruber fuel line but even if you had 15' the fuel pump shouldn't suck it shut as long as the the fuel pick up isn't blocked. Have you tried to lean the idle out yet? With a stock cam you should be pulling a little more vacuum. Unless your living at a high altitude you should be able to get more than 18" of vacuum.
