New Rebuilt Motor Will Not "Start - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2007, 08:00 AM
Hello;
I need some help on this one. I have a 1981 El Camino that came with a 267 cubic inch motor and th250 transmission. I have swapped out the 267 with a 350 that I rebuilt myself. It has not been started since the rebuild so I have to do the initial breakin of the engine, i.e start it, bring the motor up to about 2000rpm for about 20 minutes, etc.
This is the problem;
I cant get the thing started. When I turn the switch, I get nothing, the motor doesn't turn over or nothing. If I turn the lights on, only the parking lights come on. Everything worked before I took the original motor out. The motor that I put in--the 350--is from the '78-'79 era. I noticed when I bought the car a couple of months ago that some of the wires were not hooked up in the engine compartment, but it was running. At the bare minimum, I only want to get the thing started so I can break it in, then I will worry about making everything look nice. Some of the wires that were hooked up on the original motor--the 267--are not hooked up on the 350 because there is no hook up for it. The 267 was all original. The 350 has a holley 750 with vac sec sitting on top of an edelbrock intake manifold.
Correct me if I am wrong, but this is how I have it wired now;
1 wire from the firewall to the back of the motor.
1 wire from the positive post on the battery to the BATT terminal on the HEI
1 small wire going to the starter solenoid
A couple of bigger red wires/cable going to the big terminal on the starter, one of which is from the battery.
What else at a minimum do I have to have hooked up just to get this thing started.
Thanks
Old 07-09-2007, 12:03 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
That should do it..
On one of those bigger red wires on the B Terminal of the starter solenoid, Check for a fuse link,Look to see if it is open, that will disable power to the car..Or the possibility that you might have missed one wire to the B terminal.
TO get it to crank, simply jump the "S" (small terminal closest to the block)terminal to the "B" (Battery cable terminal) terminal on the starter..if the HEI is heated up it will fire and run.
You might check fire wall plugs , they could have accidentally gotten knocked off in the swap..also other spots for fuse links CAN be: Horn relay power wire, single power terminal near the battery, and sometimes a wire and link run directly to the battery.
Be sure the column plug did not slip out AND the neutral Safety switch is connected.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-10-2007, 05:37 PM
Originally Posted by newdad1
Hello;
Thanks
The wire from the firewall to the engine is a chassis ground to the block which should then have a major ground cable from the block back to the battery's negative terminal.
The best way to power wire the starter circuit is a big cable from the battery's positive post to the big terminal on the starter solenoid. (There should be a heavy but short bus bar that connects the solenoid to the starter below this terminal.) When installed in the car there is a large gauge #10 wire that goes from this terminal into the wire harness to the fuse box or the start/run switch in the latter case the wire is a fusible link, once smoked must be replaced. This is the B+ line which supplies power to the chassis systems, ignition and back from the alternator. There is another much smaller wire retuning to the small post on the solenoid which is 12 volts from the start/run switch to energize the solenoid. There should be another heavy cable that connects from the battery negative post to the engine block to provide a high amperage path from the starter back to the battery's ground side. This can be a configuration that mounts to an intermediate ground stud on the chassis, such that a cable attached from the neg term of the batt and cable from the block also attaches to the stud. There may be other smaller attachments depending upon the accessories.
To run the engine, you need all these big cables and the chassis to engine ground. The HEI can be jumpered off the battery's positive side.
Where the small (usually purple) wire attaches to the solenoid, you can install a push style starter switch (available from the parts store to bump the engine around when working on it). Connecting one lead to the small terminal and the other to the large terminal. If this doesn't crank the engine, then you've got a dead battery, bad cable or connector, faulty solenoid or starter, or a bad "bump switch".
Bogie
Old 07-12-2007, 03:16 PM
Hey thanks for the help. I started it last night at 11:30 pm, not to the liking of my neighbors.
Old 07-12-2007, 03:30 PM
Alright, that has me grinning.
Bogie
Old 07-12-2007, 03:58 PM
By the way, not to sound stupid, but what is a fire wall plug?
Old 05-04-2008, 07:38 AM
1 more thing
thats not all on one of my cars I swapped the motor out a 307 for a 350 and there was one wire that went to the distributer that hooked into a fuse panel that triggered all the power when you turn the key over without this power supplied off this tiny wire no power no turn over
Old 03-29-2009, 08:19 PM
not starting
make sure you got a ground wir from motor to body may not be groumd good
Old 03-29-2009, 09:13 PM
302 Z28's Avatar
Old thread guys, I think he may have it running by now .
Vince
Rebuilt torque converter crash Transmission - Rearend 3 05-17-2007 02:39 AM
Rebuilt Engine Squeaking, Driving me Nuts! BH69Camaro Engine 24 04-22-2005 08:51 PM
Rebuilt vs New - What's Best? dbuff General Rodding Tech 5 07-23-2004 08:54 PM
a rebuilt 1983 Chevy 4-bolt main w/ one heck of a shake RoadLizard Introduce Yourself 1 07-14-2004 06:09 PM
I want to start my rebuilt 350 but can't!!! zeeman19 Engine 2 07-05-2002 09:40 AM
