New Rods Arrived - New Crank Needed??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2013, 02:33 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Ok guys, I ordered and received my new rods for the 400ci Sprint car motor today. The problem is, they are 83 grams heavier than my old rods that the crank was balanced to so my question is, would it be cheaper to buy a new crank rather than adding almost 3 ounces of mallory to the crank? The old rods were Lunati I-beams and the new rods are Oliver Parabolic beams. I do not want to grind on the new rods.
Thanks
Old 07-09-2013, 01:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Unless you tell us how much your machinist wants to balance, and the price of whatever crank you would buy, no way for us to say.
Semper Fi
Old 07-09-2013, 01:57 PM
Banned
How about your pistons? Are they lighter? Is the weight in the big or little end? It may not be that bad to balance or it may be.
Old 07-09-2013, 02:43 PM
S10 Racer's Avatar
My new pistons are 438gr compared to the old ones at 458gr. The new rods are heavier mostly on the big end. I am trying to weigh them all now but my scale is not reading what the box says they should be so I am doubtful on the old rod weights right now.
Old 07-09-2013, 04:27 PM
Banned
If you have lighter pistons and the weight is in the big end and you have a lighter pin and ring pack even with a heavier big end you may need to lighten your crank. Too many variables.
Old 07-09-2013, 05:36 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Unlikely there will be a net loss of bobweight if the new rod's big end has the lions share of the added weight, given that 100% rotating (rod big end) is added to 50% reciprocating. WAG would be a couple ounces heavier bobweight. Might improve on this somewhat, given l/w pins if the original pins were standard weight.
Old 07-09-2013, 06:58 PM
S10 Racer's Avatar
I am learning about balancing and some terms are still fuzzy to me so bear with me while I try to understand and probably ask stupid questions. Here is what I had when the crank was balanced.
Pistons: 458gr
Pins: 144gr
Locks: 4gr
Rings: 58gr
BE Rod: 405gr
PE Rod: 172gr
Bearings: 40gr
Here is what I have now.
Pistons: 438gr
Pins: 130gr
Locks: 4gr
Rings:57gr
BE Rod:478.2gr
PE Rod:187.5
Bearings: 40gr
If someone can take these weights and figure out if my crank would need weight added is what I am looking to find out. If I need to weigh my crank to get to that figure, just let me know. I know the crank was balanced using the old setup. If weight needs added, I may just look at buying a new crank but hopefully that is a last resort.
Thanks guys
Old 07-09-2013, 09:51 PM
S10 Racer's Avatar
I must have made some enemies here, no one wants to reply?
Old 07-09-2013, 10:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Looks like the bobweight will increase by about 63.5 g, or about 2-1/4 oz.
Old 07-09-2013, 10:29 PM
S10 Racer's Avatar
So I think you are saying that the crank will need 2-1/4 oz added to it to bring it close to balance?
If I was to buy a new crank, what bobweight would I need to be looking at to order and have balanced? I assume one would want to buy one that metal had to be removed instead of added?
Can you explain how to figure the bobweight? I'm still a little confused about that because there are two assemblies per crank throw?
Thanks
Old 07-09-2013, 11:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The figure I gave was one rod/piston assembly, so the bobweight would be twice that. The crank is now too light given the new weights.
Typically 100% of the rotating (rod big end) mass is added to 50% of the reciprocating. An allowance is given for oil that clings to the assembly. This is sometimes said to be 3-5 g for a SBC and is added to the rotating.
An example of what a balance card would look like (and will show you what you need to know regarding what weights are considered reciprocating and what are considered rotating):
Old 07-09-2013, 11:21 PM
S10 Racer's Avatar
Thanks Cobalt, it's starting to sink in a little. Would a 48lb crank be heavy enough to balance to these new values?
Old 07-09-2013, 11:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You need to know what the crank bobweight "target" is estimated at. In your case, a crank w/a targeted B/W of >1857.5 g is called for provided that the values are correct on the card. I'd recommend double checking everything to be sure.
Old 07-09-2013, 11:38 PM
S10 Racer's Avatar
Thanks again. I know the rod values are correct, those numbers are from Oliver and is labeled on the box. I also know the piston weights are correct with what JE says they are because I weighed them and they were correct also. I am 100% sure all weights are correct.
Old 07-09-2013, 11:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
opening conecting rods to use Small jouornal rods with a large crank eatonde Engine 1 12-08-2008 04:22 PM
rods and crank camaroboy1991 Engine 0 05-01-2007 09:23 AM
rods and crank rustie Engine 3 09-07-2003 12:03 AM
crank and rods joes350truck1 Engine 2 03-12-2003 08:20 PM
how much will stock rods and crank take? nastynova Engine 7 12-30-2002 05:03 PM
