New roller rockers...do they need to break in? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 09:55 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I just got some brand new full roller rockers from Howards Cams (Part 90084) and I am not sure if they are OK or need some break in time? Most of the tips all roll really easily and smoothly by finger pressure, but the tips on 3 of them don't seem right to me, they are stiff and gritty. Is this me being paranoid about my first engine build or do I have a concern? I called Howards and they said no problem send them back, but I would like other opinions on the matter. Thanks!
Old 07-22-2012, 10:23 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Some company's suggest cleaning with solvent right out of the package and lubing before instalation! I do it whether its suggested or not and yes there is some break in! so use a good lubricant on valve tips or valve lash caps and push rod ends during assembly. But if their bad send them back don't take the chance!!!!!
Jester
Old 07-22-2012, 10:33 PM
Thanks for the reply Jester.
Funny you say "I do it whether its suggested or not" because there was not a shred of paper sent with the rockers with any type of instructions, nor can I find any on their website.
Old 07-22-2012, 10:57 PM
Some roller rockers are assembled at the factory's dry or with very light lube some even have like a creosote treatment applied to them because they could be on a shelf for years before a sale! Another reason to clean them and lub them is because you have no idea what they encountered in the factory like being dropped on a dirty floor LOL!! Or what a disgruntled worker might do! I just don't take chances I clean and lub! I clean my new cams too Years ago cams came with a thin coating of preservative on them like a creosote or wax I learned to clean them back then and just always have! Hell it cant hurt all it would take is a small left over filing left from machining to start the ball rolling to a failure or a few grains of dirt!
Jester
Old 07-23-2012, 04:44 AM
Irelands child's Avatar
Comp Cams says wipe 'em off and install. Crane says clean, then soak in oil. Mine are currently Crane and were well soaked in can of the same oil as used in the engine. The tip rollers are nice and smooth rolling - even the previous Comps were (and yes, they too were soaked in oil before use).
I added some engine assembly lube on the pushrod and valve tip as well
Irelands child
Old 07-23-2012, 04:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm with the others who say to not use the ones w/rough rollers. I clean everything before installing. I have to admit I don't use anything except motor oil on the rockers unless they're ball pivot stamped steel, and I don't do any special break in for roller rockers. If the cam is a new FT, the rockers get the same break in treatment as the cam, otherwise that's it.
Old 07-25-2012, 12:10 PM
Follow up: I mailed the 3 rockers to Howards Cams and they just called me back. They said that there were indeed some issues with the tips. They are going to mail me 3 new ones and do a autopsy on the old ones.
On the topic of cleaning they said it is not necessary. They clean and assemble with assembly oil at the factory and they suggest just bolting them on the engine.
roller rockers, valvetrain
any difference when adjusting roller rockers over stock rockers, using self aligning? redfish211 Engine 1 10-12-2011 03:12 PM
Oil Restrictors with Solid roller cam and roller rockers RippinRon Engine 8 05-16-2010 10:15 AM
Roller Rockers Question - Roller Pin Coming Out leejoy Engine 9 11-27-2008 12:52 AM
roller rockers or roller tip rockers Jared Engine 18 08-01-2007 01:18 PM
standard rockers vs. roller tip rockers andybird Engine 6 02-27-2003 12:18 PM
