Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New RPM Dual Quad Air-Gap Intake
Old 01-31-2006, 05:29 PM
bccsrc bccsrc is offline
Originally Posted by 406 ss monte
light switch like throttle response, that would be a good thing wouldn't it?
i'm not sure i understand the progressive linkage. how does it work? linkage like on a tunnel ram opens both carbs the same amount @ the same time, wouldn't that increase throttle response? or would it be to much throttle response? i've never used two carbs, thats why i'm asking.
The linkage kit will allow you to run the carbs anyway you want. You can set it to open both carbs at the same time or wait for the first carb to open halfway before opening the second one.
I would set it to open both carbs at the same time. Who cares about fuel mileage....
