-   -   New RPM Dual Quad Air-Gap Intake (http://www.hotrodders.com/forum/new-rpm-dual-quad-air-gap-intake-80338.html)
bccsrc 01-30-2006 08:12 PM
What do you think about the new:
RPM DUAL-QUAD AIR-GAP MANIFOLD
Designed for 1955-86 S/B Chevys, this intake stands 1-5/8" taller than the low-profile C-26 intake and offers performance improvements in the 1500-6500 rpm range. The large runners feature our unique Air-Gap design that separates the runners from the hot engine valley for a cooler, denser charge.
RPM Dual-Quad Air-Gap manifold
RPM Dual-Quad Air-Gap manifold with EnduraShine™ finish
I think I might just go this route. I already have one new Edelbrock 600 CFM carb and another one that isn't much older. I just wonder if I can rebuild that carb and give it some type of touch up?
How can I get the Edelbrock carb to look new again?
onebadmerc 01-30-2006 08:42 PM
If you are running a SB Chevy I would recommend two 500 cfm carbs with progressive linkage.
bccsrc 01-31-2006 09:46 AM
Why not 600 cfm? :confused:
xntrik 01-31-2006 10:01 AM
Either 500s or 600s, the secondaries are not going to open anyway under 6000 rpm
with progressive linkage, you will only run on front 2 bbl of the rear carb most of the time anyhow.
But you will have to tune them for the slow air flow....
fearsomefairmont 01-31-2006 10:04 AM
either is fine
Depends on the motor, if you have something "hotter" the twin 600's would be better but if it is mild vice versa.
I have 2x500's on my F-28 on a moderately worked Ford 5.0. Works great and looks absolutely awesome.
If you have 600's, use'em. The edelbrocks are vacuum secondary carbs so the 200 extra cfm shouldn't kill low end response too bad.
Good luck, and for a car seeing alot of street time the progressive linkage is a must, otherwise you get light switch-like throttle response!
Cheers,
Andy
bccsrc 01-31-2006 12:30 PM
I figured that I would also need the Linkage kit. Here is the Part:
Progressive Throttle Linkage Kits Part# 7094
Guess I will also need this:
Dual-Quad Fuel Line Kit Part# 8088
What Air Cleaner should I get?
What about painting or cleaning up my other 600 CFM carb?
406 ss monte 01-31-2006 02:57 PM
Cheers,
Andy
light switch like throttle response, that would be a good thing wouldn't it?
i'm not sure i understand the progressive linkage. how does it work? linkage like on a tunnel ram opens both carbs the same amount @ the same time, wouldn't that increase throttle response? or would it be to much throttle response? i've never used two carbs, thats why i'm asking.
bccsrc 01-31-2006 04:29 PM
The linkage kit will allow you to run the carbs anyway you want. You can set it to open both carbs at the same time or wait for the first carb to open halfway before opening the second one.
I would set it to open both carbs at the same time. Who cares about fuel mileage.... :welcome:
