New SBC 383 build question + parts list - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 12-07-2008, 06:32 PM
RippinRon's Avatar
Originally Posted by SSedan64
FWHP= Fly Wheel Horse Power
LS parts cheaper than Gen I ??
Usually its refered to as Brake horsepower. Brand new ls2 aluminum block $1100, CNC L92 heads $549 each. Shop around you would be surprised.
  #32 (permalink)
Old 12-07-2008, 06:41 PM
techinspector1's Avatar
Wiki Edits: 326
"This looks more like this than this does"....
ROTFLMAO
OK,OK, I concede.
  #33 (permalink)
Old 12-08-2008, 04:11 AM
Filmjay's Avatar
Last wiki edit: Pitted rust Last photo:
Unless I can build an LS9...or at least an LS7...for under $10K, I'm not interested. I can build a Gen1 383, or even a number of various BBC's that make the same (or more) hp for cheaper. I'm only limited by what I can fit between the frame rails....within the budget that I've specified for the engine portion of my project.
Though I WILL look into putting an LS motor together. Not that I wouldn't mind having one, I've just thought they were too expensive. Well, that and a LOT of the Z guys are doing LS1 swaps, with the odd LS2 here and there.
Tennessee has adopted nearly every emissions law as California. But, I also don't have to worry in the slightest about emissions since my '78 280Z will be titled as a Specially Constructed '62 Ferrari 250 GTO. THANK YOU SEMA!!!
*edit* - just tried to part an LS7...nope. Can't be done. Half the components aren't even available. And just the block and crank alone are near $6K. I don't even wanna think about a set of titanium connecting rods....
Of course, we can buy an LS7 crate motor for $13-$14K. Not bad, considering the technology. But I think I'll stick to my Gen1 builds. They're cheaper and make more power...with less stuff to break.
  #34 (permalink)
Filmjay's Avatar
ROTFLMAO
OK,OK, I concede.
HAHA! Thank you.
I conceded to your BBC, and may be changing my entire project around based on it...so it's about time. LOL!
Last edited by Filmjay; 12-08-2008 at 04:16 AM. Reason: edited 2nd quote into accidental double post.
  #35 (permalink)
Old 12-08-2008, 08:14 AM
RippinRon's Avatar
Can't be done? Download the GM performance catalog. Cheaper no, more power no (compared 23 degree heads to 15 degree ones lately? Less stuff to break? 6-bolt mains, 4 bolts a cylinder head. Don't me misinformed. Actual LS7 parts are expensive (the block and rods) but the rest isn't.
  #36 (permalink)
Old 12-08-2008, 09:04 AM
Filmjay's Avatar
I've spec'd a basic bare block LS7 build (minus the incidentals like fasteners, gaskets, etc...) and it's pretty darn close to the crate price. Those $1500 LS blocks are for only for L92 and LS3 or smaller.
The LS7 block is aluminum...and a bit over $4000.
The titanium connecting rods are in the neighborhood of $350-$400 EACH! (x8 = $2800 to $3200 )And the crank is $1,000.
That's $7800-$8200...and we haven't even touched the pistons, heads, intake, or ignition systems. The turn-key, crate LS7 can be had for about $13K...probably even $1K cheaper if you REALLY look around. But, by the time we get every little thing individually to build it, we won't be saving much...if any at all.
We can buy a 600+hp Gen1 BBC right now for $6000...ready to run. Granted, it's not as "cool" as a modern aluminum hp techno-monster...but it's cheaper and just as fast.
  #37 (permalink)
Old 12-08-2008, 11:03 AM
RippinRon's Avatar
The LS2 block is aluminum and its $1100 SDPC
or the iron 6.0l block for $750. I realize its a smaller bore than the LS7. but you first said you were building a 383. Who said you need the Titanium rods? Its not about being 'Cool' its about a bullet proof entirely NEW engine. That will live at 7000rpm happily.
  #38 (permalink)
Old 12-08-2008, 11:53 AM
Filmjay's Avatar
AHA! No wonder I couldn't find their site. My lysdexia kicked in every time I tried to remember Scoggin-Dickey and I kept searching Dickey-Scoggin! hahaha!
But, I wanted to stay away from the LS's UNLESS I could build an LS7.
But, after spec'ing out a few different engine combos over the last couple days, I've come to the conclusion that I went absolutely and temporarily insane.
I went "hp-mad" and lost sight of the initial "vision" of the project as a whole...which is the closest replica of a vintage Ferrari that I could build within a certain budget. The original, with a Weber-inducted V12, was only 330 bhp. (rwhp )
So, I've decided to scale back my hp demands to something a little more inline with the original.
With the engines I was putting together, this was gonna be a high-9/low-10 second BEAST! Which, while eternally fun, isn't what I really want in THIS car.
I want it to be a balanced, well rounded, well thought out machine of beauty and grace. NOT a balls-to-the-wall, hair on fire, tire shredding, monster.
So, I think I'm back to small block territory where I was all hyped up about a BBC before.
But, I may still consider an LS. I've found a couple pretty nice examples of a carb'd LS2 that would work quite well. They're at a premium price since they're from Pace Performance, but it can be done. So, I'm going to look MUCH closer at that.
  #39 (permalink)
Old 12-08-2008, 05:01 PM
RippinRon's Avatar
The ls2 or ls3 crate engines are a pretty good deal. Great power, flat torque curve and good mileage.
  #40 (permalink)
Old 12-08-2008, 05:28 PM
Banned
Personally I'd go with a LQ9 block, forged rotating assembly and CNC's L92's with some really good springs. Its extreemly durable and very budget friendly.
  #41 (permalink)
Old 04-25-2010, 09:25 PM
would you use these heads on a 383stroker?
Engine Masters Critique my 383 SBC Build 973kgt Engine 22 11-12-2008 01:14 AM
Boy are parts guys stupid, or are they? MARTINSR Hotrodders' Lounge 107 04-17-2007 11:26 AM
newbee question about 383 build jgaona Hotrodding Basics 5 08-17-2006 03:03 PM
Most Practical Cylinder Heads for 383 build up. mouseman Engine 16 01-09-2005 09:58 AM
New 383 Build glen242 Transmission - Rearend 1 12-28-2004 07:39 AM
