Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - new sbc blowby
Thread: new sbc blowby
Old 10-11-2011, 07:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by stegman
thx again, iam runnung zinc have shelf 10w40, going to run it up and down the open hwy tonight. i may do a leak down as well, but all the plugs look good and even. could i have to much oil in it? i have a 6 qt. pan and filled it to the proper dipstick mark or should i try running 5 qts. just a idea...........thx again...........
My thoughts on a deep sump pan is to use the same amount as before in order to lower the oil away from the crank and rods. Using more oil will extend the oil change interval a bit, and the oil takes longer to reach operating temp, but less windage losses and reducing air entrainment is the real benefit to me.
When you do your ring break in procedure, don't forget to slow down using engine braking as you cycle the engine through different speeds/loads. I avoid WOT runs for about 1000 miles, but other guys run them hard from the get-go and report no probs.
