Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - new sbc blowby
Thread: new sbc blowby
Old 10-16-2011, 12:37 PM
CNC BLOCKS NE CNC BLOCKS NE is offline
CNC Blocks Northeast
Originally Posted by stegman
thx for all the good advice, i ran it up and down the highway a couple of time and its still blowing oil excessively. so i did a comp test and 2 of the cyclinders show about 90 psi max, i then squirted a couple of drops of oil in the spark plug hole and it came up a bit. also blew air in and could hear a little air in the bottom of the case. should i pull the motor and see if the rings are broke or wait for them to break in???
I would do a leak down test at TDC to find out whats going on if your block was machine corrcectly the rings should be seated by now!!
I have seen circle track engines that were not prepared correctly and after 3 years or running they still had rags wrapped around the breathers because of blowby issues.
