New Shop Advice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-11-2014, 10:02 AM
Mitchman's Avatar
Grand Master of the Universe
Plenty of electric... 3 or 4, 110 legs each running all the way around. 2 or 3, 220 circuits, one for the welder(s), one for the compressor, one spare.
Run 2 air hose systems, one high, one low and clean for paint, etc. Run each all the way around the shop and put connections within 12 feet of the next. A few roll-ups on the ceiling wouldn't hurt.
Storage. Everyone forgets storage. Heavy duty racks capable of holding an entire car (or two) disassembled and off the floor.
A clean closet.
Fresh air ventilation, forced and via windows.
Lots of lights. A shop this size perhaps 3 or 4 circuits.... one over the benches, one general, one or two task.
  #17 (permalink)
Old 02-11-2014, 12:58 PM
I'm still working on my shop. It's only 24x32 with two standard garage doors and two 7' swinging doors.
I worked for about 10 years in a shop with a wood floor and found it to be way more forgiving than concrete, so I put wood floor in mine. (Wood floor, your back will thank you)
The way the doors are installed I can open all the doors and have 32' clear span opening. The air compressor is outside under a shed. As for heat I have a portable "torpedo" heater that does well enough, and for cooling (more important) it's in the shade, and I can open up the whole side to let air through.
It's still a work in progress but I'll post a few pics as soon as I can find them.
  #18 (permalink)
Old 02-11-2014, 01:06 PM
Here's a pic or two
Name:	factory 005 [800x600].jpg
ID:	120793   Click image for larger version
Name:	factory 006 [800x600].jpg
ID:	120801   Click image for larger version
Name:	airplane factory_0001 [800x600].jpg
ID:	120809   Click image for larger version
Name:	factory 002 [800x600].jpg
ID:	120817   Click image for larger version
Name:	airplane factory 001 [800x600].jpg
  #19 (permalink)
Old 02-12-2014, 06:52 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
spray foam is your friend. especially if you do a metal building. one of my barns will rain inside at the right temp. plus it helps here in central texas with heat.. good gable vents help too.
  #20 (permalink)
Old 02-12-2014, 07:17 AM
da34guy's Avatar
x2 on spray foam.
It's worth every $
  #21 (permalink)
Old 02-12-2014, 11:46 AM
Something else you might want to consider is dropping a few sections of 2" PVC with sweeps at the ends that reach across and end to end
before you pour your slab. Having a conduit from one side of the shop to the other side comes in handy later on when you want to add more wiring or plumbing.
On my own shop I built it with 16" walls and tall doors to accomadate large trucks. What it also allowed was the two mezzanines I added along the side and across the back for extra work space and storage.
BB
  #22 (permalink)
Old 02-18-2014, 12:47 PM
Thanks for all the great ideas and advice! I hope to get started in a few weeks. Keep the info coming!!
  #23 (permalink)
Old 02-20-2014, 08:51 AM
Wiki Edits: 27
compresssor location.
I mounted the 5 hp 80 Gal tank air compressor up in one corner above a work table. I made an angle iron frame and hung it from the metal truss. I wrapped the heat cord used to keep water pipes from freezing around the pump and keep it plugged in in the below freezing weather. I had one compressor pump gaul the bearings when the kids turned on the air compressor when it was 20 * F out side at night.
The retirement home we are building has a 4 car garage,2 wide 2 deep, 11 ft insulated block walls. , a separate sub panel, and has gas plumbed so I can install an overhead space heater. Enough head room , 18 X 10 door, and room for a 4 post lift with a roll around wheel kit.
  #24 (permalink)
Old 04-01-2014, 01:12 PM
Well the new shop is going up and hope to be in it in a couple weeks. That said, any advice on concrete coating / sealing? I have always tried to seal the slab with at least something, but need advice from the experts. I usually do not use a coating as I weld etc, and the coatings I know burn through etc. Any advice would be greatly appreciated!!
  #25 (permalink)
Old 04-01-2014, 01:53 PM
shine's Avatar
SPI Thug
it's nice to epoxy the floors but they can get slick . but do not put those neat little sprinkles down. you drop something you'll never find it !
there is also sealer that can be sprayed right after it is poured .
and spray foam the building then paint it white .
  #26 (permalink)
Old 04-01-2014, 02:00 PM
Already pour slab? I'd highly suggest a vapor barrier (if time)
Coating? Cost per benefit ratio on coating don't work for me. To each his own. I do see the value.
  #27 (permalink)
Old 04-01-2014, 02:09 PM
shine's Avatar
SPI Thug
if i can afford the concrete several gals if spi epoxy is no big deal.
white mud is out of sight now days .
  #28 (permalink)
Old 04-02-2014, 10:14 AM
The slab is already down and I did put a moisture barrier down before the slab was poured.
More machine shop advice. 400 sbc jtybt Engine 16 02-17-2006 05:30 PM
327 engine, machine shop advice? gavinpierce Engine 15 02-16-2006 10:54 AM
Body Shop - Advice needed beyondhelp Hotrodders' Lounge 8 12-09-2004 07:04 AM
Any advice for a garage/shop??? ConvertablePickupGuy Garage - Tools 7 03-03-2004 12:15 PM
need a customizing shop's advice.who to call? turbotim23 Body - Exterior 5 06-22-2003 12:19 AM
