New spray gun ?
hey guys I have had a devilbiss suction feed spray gun for about the last 10 years. It holds a quart of paint. It is the only style of gun I have ever used. I am looking for something smaller for painting touch ups or just one fender so I don't waste so much paint when mixing it up. I would like to find another suction gun from devilbliss like I have just holds less paint. But I can't find any smaller guns from them that are suction feed. Why does there seem to be more gravity feed guns? Also can someone recommend a gun that may only be used a few times a year with a quality spray? I will mostly use it to spray enamels paints. I don't want to spend much as the gun I have was under $50 and this one won't see much use either....
Thanks.... Brandon |
I've been doing some more research and I think the gravity feed gun would be nice to have for getting into tight spots. However:
-Is it possible to get one that is not a Hvlp type? I have never used that style of gun and hardly get to use it enough to learn. Or are the hvlp easier to use than the older style? -This may be a stupid question but how does one pour the paint into the gravity feed gun? Is there a stand included with all gravity feed guns to hold the cup when filling it? -Also once its loaded can you set it down on its side or will it leak? |
Hello I found 2 at northern freight that I might like but I they are almost identical so i need someone to tell me what the differences will affect. Here arre the links.
http://www.harborfreight.com/cpi/cta...emnumber=47016 http://www.harborfreight.com/cpi/cta...emnumber=91009 One of the guns is 5cfm the other is 6cfm. one works at 50-60psi other is 50-70psi.... -Both state they are good for oil based paint. Now I will be spraying enamel paint, is that oil based? Thanks for the help!!! |
| Time to Buy a Spray Gun | Fast Eddie D | Body - Exterior | 14 | 02-05-2009 10:00 PM |
| Why is is bad to spray primer through a exspensive gun? | hutcholdschool | Body - Exterior | 12 | 01-31-2009 09:19 AM |
| Need a good spray gun for spraying metallic base | camaro freak | Body - Exterior | 1 | 04-18-2006 05:26 AM |
| harbor freight hvlp gun | jn0w | Introduce Yourself | 2 | 06-15-2004 03:08 PM |
| ADVICE ON PURCHASING A HVLP SPRAY GUN | STATUTORY GRAPE | Body - Exterior | 38 | 05-27-2004 11:30 AM |
