Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - New street rod project
Old 03-02-2009, 06:51 AM
speedydeedy speedydeedy is offline
31 five window
Last journal entry: Moving along with patch panels.
The con to an S10 clip is the steering box usually sticks out too far in front for the sheet metal body.You will have to check your car as every one is different. Measure from the front axle centerline to the front of the steering box on the S10 and compare to your car. If it will clear the body it is the cheapest way to go.Hope this helps.We did it on a 40 Dodge and I had to cheat a little on the wheel base but it worked out.
