New streetrod (to me) column shifter stuck in park - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2013, 03:05 PM
Traded my coupe for another coupe.
I test drove this thing and have driven it around the neighborhood without any issues.
Today I changed the oil and attempted a test drive.. but I cant get the shifter out of park.
Luckily its in my garage!
This is a TH350, the column is GM and I would guess 70s or 80s Camaro? with column shifter.
Just looked and appears to have an aftermarket streetrod type neutral safety switch.
Where to begin?
Do I go inside the column or under the car?
Help...LOL
Craig
Old 05-31-2013, 03:51 PM
If it is a column ignition, try moving the steering wheel back and forth a few times. You can also try to "rock" the car back and forth (by hand or foot) while trying to move the shifter.
Failing that, there MAY be a small opening or cover on the underside of the column where a release may be.
Keep us posted please.
Old 06-01-2013, 07:41 AM
Wiki Edits: 27
jack it.
you might have to jack up the front to get the wheels off the ground. When you park it have the wheels pointed straight ahead and with your foot on the brake just in case let it roll ahead with hands loose on the wheel so it can find the no load spot.
Old 06-01-2013, 07:45 AM
I will get back to the garage today...
This is a nice coupe but like most rods had a few issues.
One was the rod from the turn signal lever to the dimmer switch (at the bottom of the column) was loose up at the lever...
Well I didnt want to remove the steering wheel so I installed a 65 Corvair floor dimmer switch, same wiring colors gotta love GM for that!
Im thinking that in doing that I may have created this issue somehow... since its in that physical area....???
Is it more likely mechanical or electrical?
NOTE: Automatic TH350, tilt column with ignition switch... Unsure what its from but looks GM, would guess 70s or 80s Camaro?
Thanks!
Craig
Old 06-01-2013, 07:51 AM
Wiki Edits: 27
Mechanical.
usually mechanical , Wheels turned , the when the wheels try to turn back it binds putting pressure on the wheel, Or it copuld be linkage mis alligned.
Old 06-01-2013, 08:46 AM
Do a GOOGLE on any combo of shifter stuck in park and theres hundreds of pages to read.... Must be pretty common!!!
But most refer to the brakes or a shift interlock solinoid...
This coupe has a 65 Mustang low pressure switch to activate the brake lights. Nothing fancy... power in power out...
Think this column is before all that electronics...LOL
Just raised front wheels off ground and turned steering wheel, jiggled ignition switch, even tried tilt in every position... still stuck in park...........
Old 06-01-2013, 09:10 AM
Banned
how about calling the guy you traded and see if it has happened to him before. Can you even start the car or is that locked too?
Old 06-01-2013, 09:24 AM
He says never.. but who knows?
Thats why I wonder if I did something...
But Ive had rods with Nova/Camaro tilt wheels and column shift before... so dont think Im that brain dead???
Ignition is fine, car starts right up.
Tilt works fine.
Steering unlocks when ignition is on...
Id hate to go to a floor shifter as this thing has a nice professional interior with a console from dash to rear....
Old 06-01-2013, 09:36 AM
Banned
not too sound like a jerk, But did you hit or drop anything around the linkage when changing the oil? I think you should jack her up put her on stands, block the rear wheels. Then get under there and have someone jiggle the shifter and see if something is binding.
Old 06-01-2013, 09:42 AM
Youre fine...
I'm sure I didnt touch anything but the drain plug...LOL
If I did something "stupid" it was inside when I changed the dimmer from the column mount to the floor dimmer.. but Ive looked there and the shifter rod is internal... dont see how I could have affected it?
Serves me right to have not driven it for a week... even if doing silly minor things... should have started it and gone around the block.. then Id know "when" this issue started and what I had just done...
Old 06-01-2013, 09:52 AM
Banned
ok then it seems to me you have pressure on the parking prawl or if this has a cable it could of frayed . Also you have your foot on the brake when you are trying to move the shifter.
Old 06-01-2013, 10:05 AM
Yes foot on brake.
No cable... from the lever at the bottom of column its a rod to a lever on the TH350.
Just lifted rear tires off the ground... and rocked them and driveshaft...
No luck...
Old 06-01-2013, 10:11 AM
Banned
get under the car and see if you can jiggle it around . also disconnect the linkage from the trans and see if you can shift the trans manually to eliminate that. also this will hopefully let you free up the linkage.
Old 06-01-2013, 10:23 AM
Should of done this first!!!
Got under the car and disconnected the shifter rod from TH350 lever...
I can move selector to all postions manually with very little force.
So trany is not "stuck" in park..........
Still cant move shifter.... so its in the column... not the trany.
Old 06-01-2013, 10:28 AM
Banned
when you changed this dimmer switch did you maybe wrap a wire around something on the inside or pulled a wire tighter to make the connection to the floor dimmer. unmount the floor dimmer and see if that helps
4t60E trans stuck in park even when in other ranges fast68 Transmission - Rearend 5 07-16-2009 01:23 PM
700r4 stuck in park! novaman30274 Transmission - Rearend 4 02-26-2007 01:07 PM
93 Park Ave Tilt Column Wiring info needed TooMany2count Electrical 3 01-26-2007 03:46 PM
Column shifter on a mustang? geaux Hotrodders' Lounge 4 12-19-2005 10:06 AM
Key is stuck in the column. BigMac Interior 13 11-06-2003 07:36 PM
