new stuff, no spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2011, 08:30 PM
new stuff, no spark
I put a new coil, cap, rotor, points and condenser on my sbc but still
no spark. What else do I try???
Old 09-11-2011, 09:53 PM
No spark
You should have 9-12 volts at the + side of the coil when the ignition is on.
Adjust the point gap to .016".
With the ignition on and the points open, remove the coil wire from the distributor cap and hook it to a spark plug. Lay the spark plug against the engine and short across the points. The spark plug should jump fire.
Ron
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 05:14 AM
blazer has spark at coil and gas no spark at plugs ricksautorestoration Engine 29 02-15-2007 08:30 AM
spark plug getting little spark 72 chevy elcamino Electrical 1 10-19-2003 04:54 PM
Cam lube gray-graphite stuff vs. the red stuff. 78 monte Engine 28 01-23-2003 10:24 PM
spark plug spark rustyrazer Hotrodders' Lounge 1 12-24-2002 03:57 AM
