New Suspension Too Stiff - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2008, 12:18 AM
scr8pin_f100's Avatar
*WARNING* Idiot in Training!
Last journal entry: Jag Front Clip
Hey guys, thought I might bring a challenge your way..This is something that I have never had happen and it is puzzling me ...I just rebuilt my GM suspension(S-10), to include all new bushings, and ball joints..Now, after putting everything back together, the suspension seems WAY to stiff..I got up on the frame, with my wife and bounced up and down..It felt like my old lowrider mini truck that I had back in high school...(absolutely no suspension travel)..So, I thought, maybe the control arms were binding where they bolt to the frame..So I loosened the bolts and retried "bouncing on the frame...Still the same...
Am I missing something? Anyone had this happen to them? Any input would be appreciated!!
Thanks!!
Old 08-10-2008, 12:39 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
If you used polyurethane bushings with the stock semi-cone shaped washers then this could be the problem. (binding)
The new ball joints may need some break-in time.
You mentioned 'got on the frame'.. If the truck is not complete (minus engine or lots of parts) then the suspension will feel stiff.
Did you replace the coils? Are they the correct ones?
Old 08-10-2008, 10:03 AM
I did not change out the springs, they are originals, just cleaned up and painted...And I used OEM replacement parts, not poly..
I was thinking about the weight thing, or lack of...the engine is not in the frame yet, nor is the front end sheet metal..But I could've sworn that the frame would articulate( if that is the right word) up and down without all of that before I rebuilt the suspension..But you are right, that might be the culprit...
I will set the engine in, just to see....But if it still has no change, any other suggestions?
Old 10-15-2008, 07:57 PM
ok, so here is a little update to this problem...And I do apologize for beating the subject up, but I know that it would be easier to remedy the problem before the body and engine is in..If there even is a problem...
ok, on to the update..I had the entire body on the frame, and I bounced up and down on the frame...The suspension is still frozen stiff...the only give was from the tires mashing down from the weight...Now, I can continue on and put the engine in, but I am REALLY fearful that when I do, I will still have no suspension...
Any more suggestions?
Old 10-15-2008, 09:10 PM
When you get the engine in loosen all the nuts on both the upper and lower control arms. The truck will settle to its ride ht. then retourque the nuts to spec. The bushings are actually part of the total spring rate of the truck and need to be set in this manner other wise they will twisted if that is the right word, to far and under to much tension at designed ride ht.
Narrowing a '73 GM B-body Front and Rear Suspension hduff Suspension - Brakes - Steering 2 09-09-2007 08:56 AM
1979 F250 Suspension MrCoolDale Suspension - Brakes - Steering 1 07-20-2007 07:05 AM
new suspension very stiff zuker60 Suspension - Brakes - Steering 6 01-17-2007 05:37 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
how to hang a C- 4 suspension ? Redmist Suspension - Brakes - Steering 1 12-31-2004 11:48 AM
