new suspension very stiff - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 10:31 PM
Hi Guys and gals,
I have just finished replacing my front suspension on my 69 Mustang. Everything is new including springs. Here's the problem, it is very hard to turn the suspension from side to side. There is no motor in the car and I can't compress the springs enough to install the shocks by jacking up the lower control arms, raises the whole car and besides I don't think I would like all that pressure on the shocks. When I do jack up the lower arms it is a bit easier to turn the steering but it is still very stiff. Is this normal and will it be easier once the weight of the engine is on the car? Thanks in advance, Rick Z
Old 01-16-2007, 10:50 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Yes, you must wait until the car is at full weight. Not to worry.
Old 01-16-2007, 10:53 PM
Thank you!! I was really hoping someone would say that
Old 01-16-2007, 11:24 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
With no shocks installed your suspension is higher than normal maximum so everything is in a bind.
Old 01-16-2007, 11:39 PM
Ya I understand that but even if I could get the shocks in without the engine in the car wouldn't that put a lot of stress on the shock? Seems that the spring would pop the top off the shock lol.
Old 01-17-2007, 02:22 AM
dawg's Avatar
NAVY VETERAN
nah alot of guys still have suspensions in when they pull or replace the motors.
Old 01-17-2007, 05:37 AM
Last journal entry: frame build
Need to remember that shocks also serve as suspension stops.
when to do the front suspension zanuck13 Suspension - Brakes - Steering 5 12-28-2005 10:39 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
how to hang a C- 4 suspension ? Redmist Suspension - Brakes - Steering 1 12-31-2004 11:48 AM
Mustang ii Suspension 41fordcoupe Suspension - Brakes - Steering 14 06-11-2003 08:12 PM
Should suspension move? (frame only) Pilot34Coupe Suspension - Brakes - Steering 6 03-31-2003 03:52 PM
