new switches... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2006, 12:13 AM
new switches...
I just got in 5 of these painless wiring switches for my custom dash I am making. I thought I was going to get 2 prongs on the back, just complete the circuit, that simple... but they have 4 prongs on the back and I don't know what to do with all of them.... Am I supposed to use a relay? Am I supposed to have ground & light sources? Can I only use 2? Here is a link to the switch...
thanks for any help,
sean s.
Old 06-02-2006, 12:27 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Two of the terminals are switch contacts, Center wiper and normally open.
The other two are lamp wire power and ground.
Relays are dependent on what you are trying to control with the switch, the contact rating Say's 20 amps..my experience with that type of switch, much over 5 amps continuous, and they tend to melt after a short lived life.
You CAN NOT control headlamps with it, and I wouldn't advise any Ignition function..without relays.
Would be OK for Audio functions, Courtesy lamps, lower current draw items without relay switching.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 06-02-2006, 12:37 AM
How do I figure out which prong does what? Just start connecting them or something? 4 x 4 = 16 diff options right?
I want to use the switches for the following:
1) Electric Fan
2) Ignition ON (spark)
3) Fuel Pump
4) Kill Brake Lights
5) Hopefully Elec. Water Pump
I guess I need a relay for all of them except the brake lights.... Can I use only 1 relay, or do I need relays for all of them?
Thanks for the help,
sean
Old 06-02-2006, 01:00 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
You Didn't get a data sheet with the switches?
No markings on the back? (Switch, Lamp)
Traditionally the Center terminal of the switch is the center wiper..start there, get your DVOM out, set for ohms, R X 1 Scale , Calibrated for 000, and throw the switch the opposite direction of the end terminal on the back of the switch..
Place a probe on the center wiper, and that end terminal, and if it's a contact, It will read 000..If it's a lamp, It will read a few ohms..but not 000.
None of those functions in my opinion should be run without a relay..Fans always require them..the Ignition , depending on the type of coil, can draw up to 40 amps, Fuel pumps can draw 15 to 30 amps, brake lamps are usually fused at 20 or 25..and a water pump is over the top..
You Will need a single relay for each function. (unless you are going to design some type of interlock system..but for basics, I wouldn't )
EXAMPLE:
  • Fan Motor Manual Control
  • Fused main power into ALL the switch center wipers, (18 ga, 5 amp fuse) and lamps. 18 gauge Ground for lamp hard ground.
  • 18 gauge wire from the Normally open terminal on the switch, to the coil of the relay , 18 gauge wire for coil ground.
  • 10 Gauge wire from a Fuse link protected buss (Direct from solenoid or single battery terminal) , to the Normally open Contact of the relay,
  • 10 gauge wire to the center wiper of the relay to the Fan motor.
Just substitute the end device for "Fan motor" to wire all relays and switches..
Doc
Innovations
GM/Chevy Pickup power window switches Stinkin_V8 Electrical 6 01-24-2009 09:42 PM
GM power window switches 5window Electrical 3 05-20-2005 01:06 AM
Big truck speedo dip switches propaniac Transmission - Rearend 2 02-11-2005 09:50 PM
electrical switches hvyeqpmech General Rodding Tech 1 07-13-2003 10:43 AM
Switches Silver_Camaro Electrical 2 06-29-2003 04:41 PM
